Switched downpipes
Old Oct 9, 2007 | 11:51 AM
bartender's Avatar
bartender
Switched downpipes
I switched to a 4'' dp from a 3.5'' dp. I mainly wanted a little better cooling. I went with the 3.5'' dp because on this forum, many years ago, I read that a 3.5 '' gave a little better low end power on a lightly modified engine. From the seat of the pants dyno, I would say that this is a true. It feels like I have lost just a bit of low end grunt, but not enough to worry about. On the other hand, it seems to spool up a little faster and I know it has to be cooling better. I have to tap the manifold for the egt probe this weekend. I was lazy before and just used the one on the dp before. The only other negative that I have seen so far, is there seems to be a little more exhaust drone than before. The mods I have are: Micro-tuner, 4'' exhaust, ais intake, and the zoo-dad mod. I have tried a Jody chip, however, it did not work for me. My hpop may be a bit on the weak side. I have just over 100k on my 03', cc, long bed, 4x4. Has anyone else switched dp before? I would be interested in hearing about their results. Later, Jonathan
Old Oct 9, 2007 | 12:03 PM
Izzy351's Avatar
Izzy351
From what I understand, smaller downpipes = HIGHER EGTs, not lower. Maybe I'm wrong here, but more restriction at the turbo outlet will get it spooled faster (hence the idea behind the wastegate!!), but I have never hear of it going the other way. And I'm a little confused -- usually I hear about losing a little on low-end with a bigger exhaust, unless I'm misunderstanding what you're getting at by "losing low end grunt" vs. "better low end power" (you stated both). Without a pyro, you really can't know that it's cooling better, so it might be worth trying both pipes again after you get it in.
I hate to put it like this because it sounds bad, but almost everything I know is the opposite of what you posted, even about Jody's chip. I'd like to know what didn't work out for you though, just for curiosity sake.
Joe
Old Oct 9, 2007 | 12:57 PM
7.3L DID TD's Avatar
7.3L DID TD
Talking
I too have a 4" down pipe and a lot of drone, and I actually don't like it, but oh well, I just turn up the radio and the cars next to me roll up their windows.
Old Oct 9, 2007 | 01:27 PM
DieselCamper01's Avatar
DieselCamper01
If I read this correctly Bartender, you switched from a 4" to a 3.5" back to a 4"?
After going back to 4" the low end power seems less but spools better since switching
from 3.5"?
Old Oct 9, 2007 | 01:30 PM
F250_'s Avatar
F250_
Hey, Joe... re-read his post. I think your confusing his observations with the 3.5" DP in comparison to what he's now getting with his new 4" DP. I had to read it twice myself to get it straight, but I believe his observations are consistent with your explanation... he just sort of did a "reverse" comparison.
Old Oct 9, 2007 | 02:43 PM
Izzy351's Avatar
Izzy351
Yeah, I see it now -- it's obvious now that you point it out, Pete. Sorry for my confusion. Jeez...
Still curious about the DP Tuner thing though. What was up with it??
Old Oct 9, 2007 | 02:46 PM
F250_'s Avatar
F250_
Jonathan, I would strongly recommend that you contact Jody and talk the situation over with him (if you haven't already).
Old Oct 10, 2007 | 11:14 AM
bartender's Avatar
bartender
Pete,
When I spoke with Jody about the chip, he is the one who suggested that my hpop might not be up to par. I get code 1211 alot of the time. Jody said this may mean that I need work on hpop. Right now I can run the micro-tuner w/o any problems, so I sent Jody's chip back. He was good to work with. If I ever get my oil pressure right, I will get another chip from him.
When I first put my exaust on in 2003, some companies were selling a resonater for the drone in the exhaust. I will try and find one of those and install it and see if it makes it any quieter. Later, Jonathan
Old Oct 10, 2007 | 06:14 PM
F250_'s Avatar
F250_
Great information.... thanks for sharing those details, Jonathan. I hope you can get it resolved soon.
