All fluid Change
Old Oct 8, 2007 | 05:19 PM
KTNC's Avatar
KTNC
All fluid Change
I want to change all my fluids to synthetic, can someone tell me if I have everything and what the capacities are:
rear axle
power steering
transfer case
transmission
radiator
Also what are the viscosities (for the oils)..?
Thanks
Old Oct 8, 2007 | 05:32 PM
FTE Trigger's Avatar
FTE Trigger
rear axle
power steering
transfer case
transmission
radiator
Thanks
I assume this is for a '06 F150? Which engine?
Old Oct 8, 2007 | 05:49 PM
FTE Trigger
From the '06 owners manual...
Engine
coolant1
Motorcraft
Premium Gold
Engine Coolant
(yellow-colored)
4.2L V6 engine 17.6 quarts (16.7L)
4.6L V8 engine 20.5 quarts (19.4L)
5.4L V8 engine 20.9 quarts (19.8L)
Rear axle Motorcraft SAE
75W-140 Rear
Axle Lubricant
(synthetic)
8.8/9.75 inch axle 5.5 pints (2.6L)6
10.25 inch axle 6.9 pints (3.3L)7
Transfer
case fluid
Motorcraft
MERCON ATF
4x4 vehicles 2.0 quarts (1.9L)2
Transmission
fluid3
Motorcraft
MERCON ATF
5–speed manual 3.75 quarts (3.5L)
Motorcraft
MERCONV
ATF
Automatic 4R70E
and 4R75E
13.9 quarts
(13.2L)4
Front axle Motorcraft SAE
80W-90
Premium Rear
Axle Lubricant
4x4 vehicles 3.7 pints (2.0L)
I'll look further for the Pwr Steering, brake fluids....
Melendez7.3
28
Feb 5, 2024 08:32 PM
hedhntr
May 2, 2012 10:25 AM
crazer42
Mar 26, 2009 03:54 PM
geoaigel
1978 - 1996 Big Bronco
17
Mar 23, 2006 09:21 PM
l.stull
Dec 11, 2004 08:57 AM
