new process 5 speed ID?
Old Oct 7, 2007 | 06:18 PM
hoxiii's Avatar
hoxiii
I have an old New Process cast iron 5 speed that I'm trying to identify. All i know is that it came out of a mid to late 60's dump truck and has a 1:1 top gear. It was mated to a spicer 5831 auxillary transmission and has the normal NP aluminum top cover and aluminum rear bearing retainer.
Cast into the side after the NP cog is "G-91861"
If anyone could help me ID this thing I'd really appreciate it!
Justin
Old Oct 7, 2007 | 06:23 PM
MisterCMK's Avatar
MisterCMK
The Spicer 5831 was used on GMC 5000 and heavier trucks. It is a 3 speed with low, direct and overdrive. Still working on more info on the spicer tranny.
Old Oct 7, 2007 | 06:29 PM
MisterCMK's Avatar
MisterCMK
From all I can find it looks like it is an NP-540 series. Is this what it looks like?
http://community.webshots.com/photo/...58970338XYglfy
Can you figure out what the first gear ratio is?
Old Oct 7, 2007 | 06:35 PM
hoxiii's Avatar
hoxiii
yeah, i know all about the 5831. that's why i picked it up, thinking about a cheap OD. But now circumstances are forcing me to unload a bunch of stuff, so i'm trying to figure out what 5 speed it is. See if it's worth me keeping or not.
Justin
Old Oct 8, 2007 | 05:43 PM
MisterCMK's Avatar
MisterCMK
See how many rotations of the input shaft it takes to turn the output shaft once with it in 1st gear. That will help narrow down the model number.
Old Oct 8, 2007 | 05:48 PM
hoxiii's Avatar
hoxiii
did some more asking around and came up with it being a 1:1 NP 540.
Justin
Old Oct 8, 2007 | 05:49 PM
MisterCMK's Avatar
MisterCMK
There were a couple of different models with the 1:1 5th though. Knowing the gear ratio for first gear would narrow it down.
Old Oct 17, 2007 | 06:13 PM
elliott's Avatar
elliott
NP trans
Try and get the ratio for 4th gear. I have a chart for some NP's 5sp's
stanzianiman
Sep 25, 2023 03:40 PM
Leroy Unlisted
27
Apr 8, 2016 12:02 AM
Elvis66
Jan 6, 2011 12:25 PM
BlueOvalBud
Feb 20, 2010 07:54 PM
philipwhite
17
Oct 1, 2002 07:31 AM
