Sponsored by: Real Truck
03' lumbar adjustment
Old Oct 7, 2007 | 12:37 PM
yamaguy's Avatar
yamaguy
Has anyone ever had to fix there lumbar adjustment? My drivers seat does not work anymore. I have not had a chance to look at it yet, and I was just wondering if anyone who has had to. Thanks, Dale
Old Oct 7, 2007 | 03:42 PM
mlytle's Avatar
mlytle
very common problem that is easy to fix. search this forum and you will find several threads on how to do it. that is how i fixed mine last spring. all it took was a washer and some jb-weld.
Old Oct 8, 2007 | 12:32 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Dale,
I don't remember when it was covered in the forums but I had to replace the driver's side on my '02 last year after I bought it. Very easy fix. Put the seat all the way forward and look under the rear portion of the seat back. The cover is held together with a plastic clip that unhooks by pushing it together and separating. Then you can look into the back of the seat and see lumbar adjuster, the best way that I can describe it is that it looks like a back bone with ribs. All you should need to remove it is a pair of pliers. Order another one and replace. The longest part of the job will be getting a new piece.
Good Luck
Dave
macstrailers
Nov 26, 2011 01:05 PM
rpxr400
Aug 11, 2009 08:06 PM
skier-24
Mar 10, 2006 01:00 PM
Dark Nemesis
Jan 1, 2006 02:37 PM
18fan
Apr 8, 2004 11:43 AM
