2007 Explorer manual lumbar question
Old Aug 11, 2009 | 02:58 PM
rpxr400's Avatar
rpxr400
My sister in-law (manual) lumbar support doesn't work any more.
Supposedly it's a **** or lever to rotate the lumbar (not an airbag on a switch).
She heard a "pop" of sorts and then the lumbar went flat.
Has anybody ever had the seats apart and/or repaired the manual lumbar? Somebody at Ford told her it was probably a cable that popped. They want $90 to diagnose it, and then an hourly rate for the repair.
I'm not afraid to tackle it if it's not a real PITA.
thanks.
Old Aug 11, 2009 | 08:06 PM
aquanaut20's Avatar
aquanaut20
Go to the Ford parts dept and get a printout of the seat/frame parts or if like me, dive right in....
4 bolts hold the seat to the floor and a wire, once out upholstery "C" clips hold seat cover on. You will find the seam for the back on the bottom of the vertical back rest.
Undo the clips and peel the cover, you may have to cut the foam to access the mechanism as it is moulded in place. Replace or repair defective part.
samts01
Jan 12, 2017 07:32 PM
Punisher29073
Nov 15, 2014 08:37 PM
macstrailers
Nov 26, 2011 01:05 PM
locknload223
Jun 24, 2011 07:56 AM
