Sponsored by: Real Truck
ac stuck on?
Old Oct 6, 2007 | 01:04 PM
BansheeBoy's Avatar
BansheeBoy
ac stuck on?
I have a 03 f350 with the 7.3 in it. Seems like my ac is stuck on. I have just the vent on, no ac (per the dial anyway...), but it is blowing what is definitely ac. When I switch it to ac, nothing happens - just keeps blowing ac as it should, back to vent and still have ac. Any ideas?
(BTW - whoever posted that power door lock fix thing - thanks! Mine pass side just crapped out, nice to see how to service an "unserviceable" actuator as opposed to giving my good friends at the dealer any dough!)
Any help or ideas on the ac thing is appreciated!
Old Oct 6, 2007 | 08:02 PM
hydro_37's Avatar
hydro_37
You have a vacuum leak somewhere. If it is 4 wheel drive it is probabily leaking around the vacuum line to the front tire.
Old Oct 7, 2007 | 07:18 AM
BansheeBoy's Avatar
BansheeBoy
yep, it's 4wd. I'll be checking that out today I guess. Thanks!
Old Oct 7, 2007 | 07:26 AM
Green_Dually's Avatar
Green_Dually
It wont leak there,unless he engages the 4x4 via the switch.
Old Oct 7, 2007 | 07:33 AM
BansheeBoy's Avatar
BansheeBoy
unfortunately, I have the switch. Think it's around that somewhere? I've never really poked around that stuff before, time to learn now I guess lol.
Old Oct 7, 2007 | 07:40 AM
Green_Dually
Ya i know you have the4x4 switch (ESOF),but the only reason you would have to look at the front hubs and lines for a vac leak,is if you flipped the switch (ESOF) and the air goes to the defrost position,instead of doing what you have the hvac switch set to.
I think that theres a switch,somewhere that malfunctioning.But it has nothing to do with the lines going to the front hubs and your problem has nothing to do with vac.
Old Oct 7, 2007 | 08:21 AM
rwilimo's Avatar
rwilimo
Sorry guys but this does not sound like a vac problem at all. If the A/C compressor is running all the time it would be electrical. Have you tried it on floor mode and what are the results? Have you looked under the hood and verified that the compressor is engaged all the time? If the compressor is actually stuck on I would start with checking for a stuck relay.
Old Oct 7, 2007 | 08:28 AM
xjoedirt55x's Avatar
xjoedirt55x
could the selector switch be the culprit?. never had the problem but just an idea
Old Oct 7, 2007 | 08:35 AM
Green_Dually
I agree,i think its electrical.Or even vac lines under the dash,but not to the hubs.
Old Oct 7, 2007 | 10:55 AM
BansheeBoy's Avatar
BansheeBoy
Just went out and tried all the settings - regular ac and max ac is normal - compressor on. When I switch to just vent on either JUST floor or JUST dash vents, no compressor. When I use vents and put on the setting for floor AND dash - compressor...seems like you guys that said switch / elec hit it. Sound like the switch went south?
Old Oct 7, 2007 | 11:18 AM
yamaguy's Avatar
yamaguy
No that is the way it is supposed to work. There is nothing wrong with your switch.
Old Oct 7, 2007 | 12:06 PM
BansheeBoy's Avatar
BansheeBoy
seriously? my bad. I though ac was not on for dash, feet, and dash/feet settings, just on for ac, max ac and defroster settings. Guess I have the afternoon free now (grin)!
Old Oct 7, 2007 | 12:30 PM
yamaguy's Avatar
yamaguy
I am glad that it is that way because when I am towing it will get hot down at my feet. That is usually the setting I use with the a/c.
Old Oct 7, 2007 | 12:46 PM
BansheeBoy's Avatar
BansheeBoy
I hear ya there, plus I love the cold anyway, so the more ac the better. I usually freeze my girlfriend right out of the truck lol. Tks fer settin me straight!
Padlock
Jul 8, 2014 02:22 PM
FordTruckEnthusaist
Jun 24, 2012 07:38 AM
BigJake86
Jul 22, 2008 08:12 PM
Tjdb2000
Jun 28, 2007 07:25 AM
oshoguno
Jul 1, 2003 04:53 AM
