I just got a 2005 6L FX4 Lariat about a week ago, and the A/C was working fine. I had to turn on the defroster because it was raining and really humid, and I went to turn on the A/C the next day and it will only blow out of the defrost vents. I figured I might have pressed the wrong button on the little computer dash thing for the A/C, cause I'm used to the manual A/C switches in the xlt's. But I've pressed about every button on that thing, and it won't work.
I'm not really sure on the 05, but there is a white one on the older models that runs across the the top of the A/C box under the hood that are known to get brittle and fall apart..
On the passenger side in the engine bay near the firewall you'll see the hose that runs to your heater core. In that hose is a round black valve that sticks up with a little arm on the side which closes when the AC is on. It is accuated by a vacuum line that slides on to a nipple in the center of the valve- the ones I've seen are gray. When this line falls off, you lose AC out of the blue and then it comes back when it feels like it. My last trucks line kept falling off causing a similar issue and I had to tie wrap it in place. Good luck.
Douglas, thank you for the picture. I didn't check that spot, but I will. I also tried turning the key without starting it and turned on the A/C to see if I could hear anything under the hood working, but heard nothing.
I had my transfer case rebuilt. Since then when I put in 4 x 4 high the a/ c goes straight to defrost. Thought I had a vacuum leak but can't find it. Any ideas?
