Sponsored by: Auxito
2000 F150 T-Case
Old Oct 5, 2007 | 06:55 PM
tcjohnson's Avatar
tcjohnson
2000 F150 T-Case
I was checking the fluids on my 2000 f-150 today, and when I unscrewed the fill bolt on the transfer case, about a gallon of fluid came gushing out. I was finally able to get the plug threaded back in, but not all the fluid came out. I am not sure how it could be this full or maybe there is another plug higher up i missed, although i didn't see one. could it be possible that there was that much pressure backed up or something like that. I had shut the truck off about 10-15 minutes before i checked and it was sitting on level ground. I have not used by 4 wheel drive for about 5 days before this happend. any ideas on what the deal is. Thanks
Tyler
Old Oct 5, 2007 | 07:11 PM
Bobby82490's Avatar
Bobby82490
For a "gallon" of fluid to come out, you must of unscrewed the drain plug, because i dont see how somebody got that much fluid in there through the fill plug without it leaking back out when you tried to put the plug back in.
Old Oct 5, 2007 | 11:28 PM
tcjohnson's Avatar
tcjohnson
That is what I can't figure out either. I pulled the plug that said fill by it and it was the top one the bottom one said drain, which i never removed. is it possible there is a third plug higher up for some crazy reason?
Old Oct 6, 2007 | 05:45 AM
Bobby82490's Avatar
Bobby82490
I guess there could be, what color was the fluid. If the fluid was gray/White maybe the tansfer case was submerged under water sometime during its life? The color should be red, i believe they use tranny fluid.
Old Oct 6, 2007 | 07:46 AM
tcjohnson's Avatar
tcjohnson
yea it was red
Old Oct 7, 2007 | 08:07 AM
steve(ill)'s Avatar
steve(ill)
it should be 2 quarts, it should be red, and it sould be up to the level of the upper fil plug. i dont know what happened, but i would pull the upper plug and let it run out to that level. put the plug back in, run a month and see if it fills again. are you loosing transmission fluid? this should not happen.--- somehow i think someone overfilled it.
Old Oct 7, 2007 | 11:20 AM
tcjohnson's Avatar
tcjohnson
well i talked to some mechanics and they said it was the input shaft seal between the tranny and the t case so tranny fluid is filling up the t case
Old Oct 7, 2007 | 12:28 PM
MisterCMK's Avatar
MisterCMK
Yup, it sounds like that seal os going bad. Check your transmission fluid and see if it is low.
Old Oct 9, 2007 | 01:39 PM
96f150's Avatar
96f150
I had this problem on my 96. There was a TSB out I believe. I pulled the case right in my garage and pulled the input shaft seal on the T-case, and put a new one in. No problem after that. I would also replace the T-case to adapter gasket while you have it apart.
Rich
Tyler S
24
Apr 14, 2025 08:35 AM
Tyler S
Oct 29, 2011 10:29 AM
Tyler S
26
Oct 14, 2011 10:16 PM
lamenytro
May 31, 2011 12:45 AM
Tyler_J
Nov 20, 2005 08:19 AM
