1978 - 1996 Big Bronco
A/C Compressor Mounting
Old Aug 16, 2013 | 07:10 AM
MadMatt65's Avatar
MadMatt65
Wanted to know if anyone with a 92-96 Bronco can tell me if they have spacers between the compressor and the mounting bracket. I can't find anything from Ford or tech bulletins. Has to be factory installed air. I've been looking at some pics and videos and the ones I can see....there are no spacers. Pulled my compressor off due to it not lining up with the other pulleys and annoying belt squeal. I've got the whole mounting bracket off right now. Gonna pull the leaky steering gear out and get everything cleaned up.
Old Aug 16, 2013 | 09:10 AM
gatorfor88's Avatar
gatorfor88
I cant speak positively about your Bronco, but Ford usually doesnt have spacers between compressor and bracket. If spacers are required it's been my experience they are between the mounting bracket and the water pump/cylinder head. Hope this helps you.
Old Aug 16, 2013 | 09:21 AM
Torky2's Avatar
Torky2
No spacers of any sort on my '94 351, er, 5.8L. Three bolts hold bracket onto cylinder head, bracket has one larger clearance hole so water pump stud (unthreaded on outside end) sticks through with no interference or connection.
And compressor fits tight to bracket with the four mounting bolts.
What engine?
When you say not lining up with the other pulleys, I think of forward-rearward misalignment, I don't see anything there to cause something like that on the 351. Unless the compressor had the wrong clutch/pulley assembly or something like that.
Old Aug 16, 2013 | 04:34 PM
MadMatt65's Avatar
MadMatt65
What engine?
It's a 351. There were hex head nuts between the compressor and the bracket on the 4 mounting bolts. I was kinda wondering if previous owner lost "spacers" when they removed the compressor. Maybe installed because of belt squeal? From I see on others....there are no spacers. Looking at the compressor from the top...it looks aprox. 1/2" - 5/8" too far forward. Right now, I have the mounting bracket off so I can get a new power steering pump and steering gear. Gear is leaking and pump is very noisy, (probably run dry). When I took the bracket off, it was flat against the head and all 3 bolts were tight.
A new water pump and timing cover was installed, (by previous owner). I can see changing the water pump...but the timing cover, i don't know. I couldn't see anything wrong with it. I was thinking about trying to shim that un-threaded stud to kick the bracket back at the top. I'll know more when re-assembly starts.
Old Aug 16, 2013 | 07:53 PM
Torky2's Avatar
Torky2
I would not do anything that puts different pressures on or torques the timing cover. The timing cover to block sealing is iffy enough on these engines.
A sanity check - I have my old seized compressor still lying on the floor.
On the top of the FS-10 compressor are two mounting bosses, that the compressor to bracket bolts go through. The mounting bosses are very square. I measured from the front face of the top front mounting boss to the back face of the pulley. It was 1.5".
Also, the 4 small-headed long bolts that hold the front cylinder head of the compressor on to its main body, the rear face of the pulley just clears the heads of those 4 bolts.
You could measure your compressor, to check the compressor mount-to-pulley offset. If you measure something well over 1.5" offset, then I wonder if it has the wrong compressor on it.
I assume (but don't know for sure) that the bracket was the same for 1993 & 1994. Both used the FS-10 compressor, but the 1994 system was R-134a, rather than R-12 of the previous years. A quick check of Rockauto showed the same compressor part number for 1993 & 1994 in the aftermarket parts biz.
Old Aug 16, 2013 | 08:45 PM
WhyFord's Avatar
WhyFord
There are a couple "hollow studs" between the compressor mounting holes and the bracket: I think the purpose of those are for lining up and temporarily hold the compressor in place when you insert and tighten the bolts. But sometimes those "hollow studs" got compressed and look just like "spacers". If this is the case, just take them out and throw them away instead of letting them in the way to have a flat mounting surface.
FuzzFace2
Nov 3, 2019 09:26 AM
weswes01
Apr 16, 2017 09:01 PM
VQ2Fast4U
Jan 18, 2007 07:02 AM
mstoned1
Offroad & 4x4
Dec 16, 2004 01:54 PM
Bassfever1
Apr 24, 2004 04:42 PM
