spring code?
Old Oct 4, 2007 | 09:18 PM
mudmaker's Avatar
mudmaker
spring code?
I am looking into replacing my front springs due to the fact that they are not as perky as they once were. My question is does anyone know if there is a heavier front spring from Ford available and if so what code it would be.
Thanks
Old Oct 5, 2007 | 12:05 AM
jtharvey's Avatar
jtharvey
I wonder if the springs out of a heavier truck, like a 450 or 550 would work?
Old Oct 5, 2007 | 04:40 PM
Stewart_H's Avatar
Stewart_H
Mud, are ya replacing the springs on your Ex, or your F350?
Stewart
Old Oct 5, 2007 | 05:37 PM
mudmaker's Avatar
mudmaker
My F350. The local dealer cant even answer my question, so they say
Old Oct 5, 2007 | 05:59 PM
Stewart_H's Avatar
Stewart_H
Mud, you have a PM.
Stewart
Old Oct 5, 2007 | 08:38 PM
mudmaker's Avatar
mudmaker
THanks Stewart, I want to do the spring swap on the X, but the pickup has a priority right now. I'm going to use some X code springs. Its amazing how clueless the parts guys at my dealer are. I think I'll just order them from direct ford parts.
Old Oct 5, 2007 | 09:03 PM
Stewart_H's Avatar
Stewart_H
THanks Stewart,
...I'm going to use some X code springs.
You're welcome bro.
I was wondering if you'd go for the snow plow X code springs!
Stewart
Old Oct 5, 2007 | 10:15 PM
bdrummonds's Avatar
bdrummonds
There is a two-character spring code on the vehicle certification sticker on the lower doorpost behind the driver's door. The first character is the front spring code, and the second character is the rear spring code. A common spring code for a CrewCab 4x4 would be VB. The V means 5,200 pounds front springs, and the B usually means the rear springs on an F-350 SRW. However, some F-250s also have code B rear springs.
Any pickup can have any available front spring code - depending on options, and it doesn't matter whether F-250, F-350 SRW or F-350 DRW. Here are the spring codes for the front leaf springs on '99 thru '04 PSD 4x4 pickups:
T = 4,400 pounds @ground
U = 4,800
V = 5,200
W = 5,600 (rare on a pickup)
X = 6,000 (only with snow-plow pkg on a pickup)
Rear spring codes:
A = F-250 & Excursion (6,084 pounds @ground)
B = F-350 SRW (6,830 pounds @ground)
C = F-350 DRW (8,250 pounds @ground)
If you already have code B rear springs, then you already have the same rear springs that are on F-350 SRWs.
If you have Code U or V front springs, then you might like the code X front springs. In addition to giving you a little more weight capacity on the front end, they will give you a one to two inch lift of the front end.
If you wanted to really beef up the springs on your F-250, then put the code X front springs and the code C rear springs on it (they should bolt on). But be warmed it will then ride "like a truck". <?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" oreferrelative="t" o:spt="75" coordsize="21600,21600"><v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><vath o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></vath><?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shapetype><v:shape id=_x0000_i1025 style="WIDTH: 212.25pt; HEIGHT: 68.25pt" type="#_x0000_t75"><v:imagedata o:title=\"\" src="file:///COCUME~1BRANDO~1LOCALS~1Tempmsohtml1\01clip_imag e001.wmz"></v:imagedata></v:shape>
BTW, NEVER change leaf spring
s without replacing all the U bolts with brand new U bolts.
hope this helps.
BD
Old Oct 5, 2007 | 11:51 PM
jtharvey's Avatar
jtharvey
Thanks for that info. I've been wondering that for a long time. I just checked mine, it's a VB code. I'd really like a better ride, and rarely haul anything close to my trucks capacity. I'm thinking UA might be the way to go for me, and add some air bags for those cases when I am hauling a big load.
Old Oct 6, 2007 | 12:26 AM
Stewart_H's Avatar
Stewart_H
If you take your springs off, hang on to them. For us Excursion owners, a common upgrade we do (to cure the inherent wander problems we have) is to swap out the POS OEM springs Ford put on our rigs for F250/F350 springs. The most common springs being the V code and B code springs.
You can probably find someone fairly close to you, willing to drive to your location and pay you cash money for the springs.
It's always nice to have some mod money for your truck!
Stewart
Old Oct 6, 2007 | 09:19 AM
bdrummonds's Avatar
bdrummonds
Yeah I hear ya Jeremy, I am one of the lucky guys who got a F250 with the VB code springs. I would like to respring the front with X springs, but then I think it will beat me to death as a daily driver.
Old Oct 6, 2007 | 09:51 AM
mudmaker's Avatar
mudmaker
I just ordered my X code springs. I guess I ll find out how harsh the ride will be.
Old Oct 6, 2007 | 05:40 PM
Mr. Bob's Avatar
Mr. Bob
Im interested now
gventura18
Aug 15, 2016 12:18 PM
ithaca1230
Feb 13, 2014 03:08 PM
bigboylk
Apr 15, 2013 06:20 PM
Sader
May 21, 2011 07:33 AM
tpafire5
Apr 14, 2011 03:29 PM
