average life
Old Oct 4, 2007 | 08:11 PM
92 f-150's Avatar
92 f-150
average life
on average how many miles do these engines last for before you get into those pricey repairs? my truck has 217000 on it and runs better than my van with 167000.
Old Oct 5, 2007 | 09:43 AM
6CylBill's Avatar
6CylBill
Anywhere around 300K miles, depending on how the driver takes care of the machine. Remember, the 240 and 300 are almost twins. My beast has 207K miles. I'm hard on it too
Old Oct 5, 2007 | 10:10 AM
jonbass40's Avatar
jonbass40
The body will rot off and the frame will break before that 300 gives up the gost. they can easily run 320 plus as long as they are taken care of
Old Oct 7, 2007 | 01:33 PM
83Van's Avatar
83Van
300k is about right assuming you A: treat it well and B: don't have a "newer" block with the craptastic composite [aka plastic] timing gears. A '92 300 would have said composite gears. No set mileage as to when they should be replaced, their failure seems quite random. Replacing them is cheap enough, just a lot of labor to get to. On the upside it's a great excuse to install a new cam
Old Oct 7, 2007 | 03:45 PM
MBDiagMan's Avatar
MBDiagMan
Just change oil hot and change oil often. Keep it full of fluids and drive it like you stole it. It'll go!
Old Dec 19, 2007 | 09:37 PM
83maverickf-100's Avatar
83maverickf-100
what the hell do you drive them like my dads not mine he put 783 000 on his 300 before she died mine has 167 000 i have a long time left
Old Dec 19, 2007 | 11:06 PM
Col Flashman's Avatar
Col Flashman
I've seen most users I know do 500,000 - 600,000 on their 300 I-6's before anything really expensive needed to be done to them.
Old Dec 19, 2007 | 11:10 PM
condolan's Avatar
condolan
My truck got a new block at 70,000 original miles.
It ended up just being a defective harmonic balancer, but my father was not happy with the technician who diagnosed it as a bad engine. Now its got 103,000 miles with only 30,000 on the motor. I probably won't see the end of that engine before I give it away or sell it someday...if I ever do.
Old Dec 20, 2007 | 02:05 PM
Silver Streak's Avatar
Silver Streak
Mine's going strong at just under 330k miles. I changed the timing gears at about 300k after I got home from a 1500 mile road trip and spent the whole time worrying about them.
Old Dec 20, 2007 | 03:16 PM
1982fordf100's Avatar
1982fordf100
How did the fiber timing gears look at the 300k mark? I know my 82 F100's steel timing gears had little wear at 312k when I rebuilt the engine. My dad's 92 f150 has 202k and my 95 f150 has 162k.
Old Dec 20, 2007 | 03:18 PM
Mtthwvn73's Avatar
Mtthwvn73
Mine's a youngster...it only has a quarter million. I plan on getting about 300-350K out of it before it needs something major, that's if I get lucky.
Matt
Old Dec 21, 2007 | 08:02 AM
Silver Streak
They still looked brand new, but from previous experience I can tell you that fiber parts seldom have visible evidence that they are about to fail because their failure starts from the inside.
ciscofreak
6.7L Power Stroke Diesel
84
Jul 31, 2021 04:39 AM
coachvassar
2009 - 2014 F150
May 16, 2017 11:03 PM
tomohara
Sep 17, 2016 07:07 PM
Jerry Husky
May 4, 2016 01:42 PM
builttoughf350
Sep 13, 2010 06:46 PM
