Wiring question
Old Oct 4, 2007 | 09:10 AM
OldgreenF1's Avatar
OldgreenF1
Wiring question
IM putting in a new harness and running an older dual point distributer in my 302. No electronic module box.
My instructions dont show the old points type so here I am.
I have a coil wire going to + on coil or?
Ignition switch wire to solenoid Switch side.
I need to know where my dist wire hooks up+ or - and my coil.
IM using a Rebel wire harness
Old Oct 4, 2007 | 09:16 AM
fiftysixfordf250's Avatar
fiftysixfordf250
The distributor wire hooks up to the negative side of the coil. Hope this helps. -Steve
Old Oct 4, 2007 | 10:06 AM
OldgreenF1's Avatar
OldgreenF1
Thanks Steve.
Old Oct 4, 2007 | 10:07 AM
Cyruscosmo's Avatar
Cyruscosmo
Your positive coil wire goes to your balast resister or resister wire then on to the key. When you start the vehicle there is a second terminal on the starter solenoid that by passes the resister so you get a nice hot spark, that wire go's directly to the positive on the coil. The negative coil terminal has one wire to the points and "maybe" a wire going to a tachometer if you have one.
OldgreenF1's Avatar
OldgreenF1
Thanks Guys
rustywheel68
Electrical Systems/Wiring
Mar 20, 2013 08:26 AM
rustywheel68
Oct 2, 2012 11:14 AM
hivolt5.0
Jun 22, 2011 08:17 PM
oreodog
15
Jun 5, 2007 01:59 PM
250-highboy-76
15
May 11, 2006 05:24 PM
