points ignition & resistance wire
scratching my head on this one.
1965, points ignition (triggering a TFI ignition module, but i'm not sure that matters here)
i can see the resistance wire under the dash. it disappears into the harness, and i don't see any evidence of it being bypassed before it hits the firewall.
but- with the points closed, i'm getting 12v at the coil +.
i pulled the wire off the coil, and measured resistance from there to the key switch- 2 ohms.
how could the wire be showing 2 ohms, but i'm still getting 12v at the coil?
Jim
the project i'm working on is putting in an E-core coil (to match the TFI ignition module i'm already using). Since that coil can handle 12v, I got impatient and just bypassed the resistance wire last night.
here's what i *think* was messing up my readings:
even though i was checking with the points closed- my points aren't wired directly to coil -. they're wired to the TFI module. the TFI module has a separate wire that goes to coil -.
i'm assuming now that closing the points doesn't necessarily mean that the TFI module is allowing current to flow through the coil.
if that's the case, the suggestion to ground the coil or simply check with the engine running, would have been spot on.
thanks to both for your replies...now i wish i'd waited to bypass the resistance wire so that i'd know for sure why my readings were weird.
