Basic engine build up
Old Dec 8, 2001 | 06:00 PM
jlasater's Avatar
jlasater
The 390 engine I have is bone stock, and has probably 4,000 miles on it since it was completely rebuilt. I'd like to pep it up a bit, but not make it into a drag racing machine. I'm looking at using the Holley 600cfm that is on it, but installing the Edelbrock Performer package (manifold and torque cam) plus maybe a good set of headers. Realistically, how much performance would this add? Factory rating is only 180hp. It has a C6 tranny as well.
Old Dec 8, 2001 | 08:17 PM
Ratsmoker's Avatar
Ratsmoker
Was the engine a complete stock rebuild? Would have been nice to put a little hotter cam than stock. The stock cam is pretty small. I think it has a .481 lift and around a 195 duration at .050. If it is still stock the upgrades you have mentioned should give you a good wake up. Maybe shy of 250HP. Not to mention the 50 pounds you are going to save by going with the aluminum manifold.
Old Dec 8, 2001 | 08:30 PM
jlasater's Avatar
jlasater
I bought the truck from a friend of mine and I had reassembled the engine for him about 6 years ago. Everything is totally stock to my knowledge.
So what would it take to get the engine to 350+ HP on pump fuel without making it an RPM-race engine? I'll mainly use it for hauling trailers.
Old Dec 8, 2001 | 11:18 PM
Ratsmoker's Avatar
Ratsmoker
You will definitely need a bigger cam. I would stay away from either of the edel cams. With the head designs on the stock FE heads a dual pattern cam will really help you out. Putting 1.65 exaust valves will really help but that is pretty involved. The 600cfm carb is a little small for 350HP but will probably get you by. Your compression is what is REALLY hurting you. You could bump it up to 10:1 by using the TRW L2291 forged pistons. They are about 32 bucks a pop from summit. Upping the compression will help a bigger cam work better. You could probably stay with the pistons you have and "cam" your way up to almost 300. I'll get on the desktop dyno when I get home and tell you what it says. It is not absolutely accurate but will give you a good idea. Did you do the oiling mods when you rebuilt it? If not I would at least pull the pan and put a HV/HP pump in it. The stock oiling system is not made for turning the revs you are going to need to get that much power. If you are willing to take a little time and spend a little money 350HP will be no problem. Let us know if you are willing to change the pistons out and we can go from there. Also I don't know what gear ratio you have in the back but you can really wake it up if it is a low ratio right now and you switch to a higher one.
Old Dec 9, 2001 | 12:05 AM
proeliator's Avatar
proeliator
> Also I don't know what gear ratio you have in the back but you > > creally wake it up if it is a low ratio right now and you switch to > a higher one.
Yea, Rats one to talk about rear gearing
Old Dec 9, 2001 | 03:06 AM
Ratsmoker's Avatar
Ratsmoker
You would be correct. I have a serious problem back there. All in good time man.
Old Dec 9, 2001 | 09:13 PM
proeliator's Avatar
proeliator
Just busting your chops bro...by the way, congrats on your build up, sounds like you did it right.
Old Dec 10, 2001 | 12:36 AM
Ratsmoker's Avatar
Ratsmoker
I know. Thank for the compliment. What gear do you think I should run? I am debating between a 3.89 and a 4.10. I don't do too much interstate driving and at this point gas mileage is obviously a concern. I'm just thinking with posi and road slicks a 4.10 still might be a little too much. Basically looking for best performance.
Old Dec 10, 2001 | 04:14 AM
Ratsmoker's Avatar
Ratsmoker
Scratch that about the gas mileage. I meant to say gas mileage is of absolutley no concern.
Old Dec 15, 2001 | 10:24 PM
CRJ900's Avatar
CRJ900
Old Dec 16, 2001 | 01:44 AM
gtex's Avatar
gtex
I'm running 4.10 gears on my 69 F250 with 390 and C6. I feel like it's too much gear. It's almost like I'd be faster with 3.73 or 3.55 gears. I feel like I'm closing in on the red line without going fast enough. I'm running 255/70r16 tires that could stand to be a bit taller, which might help. But, I really wanted 4 same size tires just for the sake of rotation. Has anybody seen some sort of chart that shows 1/4 mile estimated times versus HP, weight and gear ratio? I have yet to actually run a 1/4 mile drag, but I suspect that I would run out of RPMs before I ran out of track.
Greg
Old Dec 16, 2001 | 02:34 AM
Ratsmoker's Avatar
Ratsmoker
How far from stock are you? I would definitely agree that 4.10 is too much for a stock 390. I have 3.25 gears now and I shift into 2nd at about 45 mph (loosing rubber) at 5000 rpm and by the time it hits 3rd I'm going about 85 - 90. I'm looking for a gear to go well with posi and slicks and 295/50R15 tires. E.T. is my main concern. Not going higher than 4.10 though.
Old Dec 16, 2001 | 09:10 AM
gtex's Avatar
gtex
Who me? Stock, not so much.
Edelbrock RPM intake, Ed Performer 750 Carb, Crower Power Beast cam, All MSD ignition, Dynomax headers 4 into 1.
Currently runs good to over 6000RPM in park, I have seen 5500 RPM in first and second.
Greg
Old Dec 17, 2001 | 06:52 PM
proeliator's Avatar
proeliator
It really depends on the size tires you run, Rat. I run 4.10s with 35s and its not even close to too much gear. Also, what rpm do you want at 60 mph?
Countryboi
Mar 11, 2016 11:38 AM
Pete S
Feb 23, 2016 07:13 PM
john mullen
Jul 5, 2015 09:19 PM
Josh913
15
Feb 27, 2004 07:45 AM
txzaphod
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Oct 25, 2003 09:58 PM
