Edelbrock performer RPM
on
I see your planning to get an intake. So you don't have it at hand.
It should have the vac. port right behind the carb. Or in front of carb. depends which intake you get.
And if for some reason theirs is not any. Then use a aluminum carb spacer tall enough you can drill a hole and tap with 3/8 pipe thread and screw in a nipple and hook the P/B there..
Most all 4brl carbs have the base nipple for the PCV.
Orich
Orich
Orich
Orich
on
The Performer RPM has the port on the front of intake, driver side. You can see how I routed mine in this pic for the most I only had two options and I chose booster there, and PCV to throttle body.
Oh, and if you have an Automatic, I ran the vacuum to back of throttle body, carb should be similar.
