WANTED PERFORMANCE BUILD HELP 262 L6
Old Jul 1, 2015 | 06:56 PM
john mullen's Avatar
john mullen
I AM LOOKING TO TALK WITH ANYONE WHO HAS BUILT UP THE 262 FORD TRUCK FOR RACING PURPOSES. LOOKIN FOR PERFORMANCE PART SUPPLYERS IE, FORGED PISTONS, STAINLESS STEEL VALVES, ROLLER CAMS, OR ANNYTHING HIGH PERFORMANCE MADE FOR THIS ENGINE ..
THANKS JOHN
Old Jul 1, 2015 | 09:52 PM
tinman52's Avatar
tinman52
Welder User
You have a tough road ahead of you. Even stock replacement parts are hard to find.
They are kind of a one off motor.....they look like a 215-223, but almost no internal parts interchange.
When I rebuilt mine about 20 years ago, parts were scarce. No speed parts are available that I know of, except intakes and headers. Stock cams don't exist, unless you can find NOS, hopefully yours can be reground to your spec
They have forged cranks and flat top pistons though.....and good sized valves.
I always thought these engines would be suited for a supercharger, that may be your best option
BTW, have you checked out fordsix.com? Lot's of six info there....
Old Jul 5, 2015 | 07:29 AM
Santiagoeford's Avatar
Santiagoeford
Have you found out anything as far as speed parts for this motor? All I ever found were intake and headers. BUT. I have seen that there is a 277 stoker for this motor. You bore the motor .060 over and use 292 Pistons. I can't remember exactly where I found this info
Old Jul 5, 2015 | 09:38 AM
john mullen
I have done extensive research on this engine and find as you have those speed parts are all that is available I understand that the crank can be offset ground to increase the stroke and use the 292 rod and piston. I hope to have a set of forged pistons made. my biggest problem is finding a 262/6 engine in the first place... I am determined to find one. it will be used in a record attempt at Bonneville
Old Jul 5, 2015 | 12:46 PM
Santiagoeford
HOLY CRAP! Your takin it to Bonneville?? Dude take lots of videos
Old Jul 5, 2015 | 01:07 PM
john mullen
I am only the engine builder. the owners are from Oklahoma City and asked me to R and D the engine for the attempt . I'm hopping to find a donated engine for the experimental build or at least a shared interest in it .I have done extinctive computer modeling and think I can produce an engine with ???? H.P.....I cant elaborate on that at this time. but something over 1.2+ HP per CU. IN. we are still in the planning stages and looking hard for this 262 big 6 engine. HELP ANYONE ???
Old Jul 5, 2015 | 03:51 PM
ALBUQ F-1's Avatar
ALBUQ F-1
None of the 48-56 trucks that this forum focuses on used that engine. Are you also posting in the 57-60 and 61-66 sections?
Old Jul 5, 2015 | 04:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
262 I-6: Optional = 1961/64 B/C/F/N500/600 & 1963/64 F100/250.
Next to no parts are available NOS for the 262, as all are obsolete.
Old Jul 5, 2015 | 06:01 PM
john mullen
Yes ALBUQ F1, I am posting everywhere I can to get any info that might be out there. Thank you for your reply to my post. I know I have a very difficult job ahead of me but I'm not ready to give up just yet
Old Jul 5, 2015 | 06:06 PM
john mullen
Maybe what I should be asking is what could be built from the 223 engine as far as CU.IN.capability
Old Jul 5, 2015 | 08:08 PM
tinman52's Avatar
tinman52
Welder User
Just curious, what class are you planning to run in? Production pickup?
Honestly, I think the 262 would be a better base for higher HP....everything is much beefier.....crank etc.
I'm sure there is one out there, maybe try posting on the HAMB?
This engine may not be on topic to this group, but we're all gear heads here and (most) can appreciate what you are trying to do.
Old Jul 5, 2015 | 09:19 PM
john mullen
Thanks tinman, I appreciate all the responses from this group. I really want to find that engine .Bonneville ...PP class XO engine
Kyle Wood
17
Nov 12, 2016 05:01 PM
mudguts
Nov 5, 2012 08:00 PM
broke77f100
4 Cylinder Engines
Mar 20, 2006 10:48 AM
RUFUS79
May 30, 2003 11:28 AM
Ford_Six
Jan 15, 2003 07:26 PM
