FE Head question
Old Jan 3, 2002 | 07:37 AM
dinosaurfan's Avatar
dinosaurfan
FE Head question
Old Jan 7, 2002 | 07:34 PM
jmnnn's Avatar
jmnnn
FE Head question
Although my FE is not in a truck or car, I found this site to be extreamly valuable for FE engine information.
I am rebuilding a 352 that was built for marine use (1965 Century). Upon teardown I noticed that I had a mis-matched pair of heads. The engine had a valve job done years back by a Ford garage and I remember they replaced a head due to a crack. The original head is a C4AE-6090-G and the replacment head on the other side was a C6AE-R. They apear identical except I noticed that the exhaust ports on the C6AE-R were not as tall as the C4AE-6090-G. The exhaust manifolds that the engine uses have ports that match the taller exhaust port.
I would assume I should find a matched set, either way. Any suggestions between the two, or am I better off with the C4AE-6090-G because it has the taller ports?
Thanks,
Old Jan 7, 2002 | 09:43 PM
AFX427's Avatar
AFX427
FE Head question
Both of these heads have the same combustion chamber volume so compression is equal on both sides of the engine (assuming good rings and valves etc.). However the C4AE heads were also installed on 390 engines which may account for the taller exhaust ports, whereas the C6AE R heads were a 66 352 item only. You may go to a lot of trouble to find another C4AE head for little or no performance gain. I would say that if the heads are sound and the valves good, use them.
Mark
Old Jan 7, 2002 | 11:06 PM
FE427TP's Avatar
FE427TP
FE Head question
Both heads are good heads the C6AE-R is also called the poor mans Cobra Jet head as it was installed on virtually any engine in 1966 and 1967, yes this means more than just the 352. And it can be fitted with CJ valves to be virtually identical to the cobra jet head. It has been found in both cars and pickups. The C4AE-G head was used on a lot of engines too and is likely to be more common as it was a standard head whereas the C6AE had several versions at the same time such as the C6AE-J which was on my 410. I would say find another C4AE-G head, with a good valve job I've seen flow bench numbers that nearly rival the bigger valve CJ head. And there are two different exhaust ports one being lower than the other as emmisions stuff started.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
