confusing
Old Oct 1, 2007 | 12:34 PM
eviltrekker's Avatar
eviltrekker
confusing
just got the cps installed and last summer installed new wiring harnessess for glow plug and injectors, but started truck up and it still dies after 5 mins running.any suggestions on what could be the problem. wondering if cps could be bad,its brand new.
Old Oct 1, 2007 | 12:57 PM
Cuda_jim's Avatar
Cuda_jim
It could be a CPS...even new ones can go bad. How does it run until it dies? How does it die? suddenly or start missing and then die?
Old Oct 1, 2007 | 12:58 PM
Cuda_jim's Avatar
Cuda_jim
Are you getting any codes, CEL on?
Old Oct 1, 2007 | 01:31 PM
eviltrekker
runs fine then starts missing then runs good then misses then dies and starts right back up.check engine light comes on when it starts messing up. dont have a code reader yet
Old Oct 1, 2007 | 01:59 PM
tjbeggs's Avatar
tjbeggs
Sounds like under valve cover harness related. also check the main wiring harness where it lays over the drivers side valve cover. it could have a wire rubbed bare and touching the VC.
Old Oct 1, 2007 | 05:57 PM
eviltrekker
also battery light is on had to jump start it
, think alt. might be bad would that also have something to do with it not running right
Old Oct 2, 2007 | 08:24 AM
tjbeggs's Avatar
tjbeggs
it might but unlikely. I would get the alt checked out first then see where you stand though.
Old Oct 2, 2007 | 10:30 AM
Cuda_jim's Avatar
Cuda_jim
Could be if the voltage is low enough to the IDM. It needs a lot of voltage to fire the injectors. It actually increases the battery voltage up to 115V DC. Low voltage in....low voltage out.
Check the connections on the alternator. The small wires on the top get abused from people laying on them. Wiggle them with the engine running and watch the volt meter....it shouldn't move.
Old Oct 2, 2007 | 11:01 AM
caseydudem's Avatar
caseydudem
I have had some of those same issues and it turned out not to be a bad alt or battery, but that I had a bad ground some where. I would look at some of your wiring grounds. Have you put anyhting new on that had to be wired in? Just a hint from what I have experienced.
Doc Wright
Sep 22, 2016 11:00 AM
rlansdon
31
Apr 20, 2016 07:55 AM
Fordbronco69
Jul 27, 2013 10:48 AM
hink10
44
Mar 12, 2011 11:48 AM
Dewalt17fan
21
Jan 22, 2007 06:18 PM
