Could my truck be breaking CPS's?
Hello everyone,
I've installed three new CPS'S over the last month and still my truck is not running correctly. Well, actually it's not running right now. It'll crank and run very rough for maybe 10 seconds then die. I've replaced CPS 3 times and I'm still getting the P0344 code! The first two cps were crappy autozone ones but the last one was the Ford purple gasket. What other possibilities could there be? Is there a wrong way to install? I did notice every time I pull one off there's a bit of oil on it. Is that normal?
Thanks in advance!
Thanks in advance!
It seems logical to do that but I have not. I'm not with my truck right now but what does the other side of the harness connect to?
Okay so far I found that I checked the fuel pump pressure at the Schrader valve and the crank pressure was 15 psi. And this was using a regular tire gauge mind you so it could be wrong but does that sound like it could be a fuel problem rather than a CPS problem? Like it was mentioned before long cranking could set a CPS code so I wonder if my fuel pump is the culprit and not something else? How could I test that?
About a month ago I was driving down the road and suddenly lost all power. Replaced CPS on the side of the road and drove it home. Drove it again and lost all power again and I could have the pedal floored and it would turtle crawl and suddenly it would all come back as if normal then lose all power randomly again.
The current status of the truck is that it will only start if I disconnect the ICP and that is quite rough and will only continue to run as long as I give it fuel. It has to crank for a bit before it will start.
What I've done thus far to troubleshoot: Map sensor hose was broken so I replaced, (it's throwing a code related to this, could that be what's causing it to lope?) replaced uvch and pigtails, glow plugs (since I was changing uvch), ordered another ICP because there's oil in the pigtail and connector area, IPR nut is secure but pigtail's gasket fell apart (hopefully will get a replacement today), also cleaned the fuel mesh in case of blockage. I've gotten a few codes using the Ford scanner my friend brought over and here are the codes: P0344 (Cam intermittent signal), P0603 (Keep alive memory error), P0237 (Turbocharger boost sensor)
