destroyed a running board
Old Oct 1, 2007 | 06:30 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I don't think you can really repair c.f. the way you can fiberglass. It might look OK, but I doubt you could stand on it.
Old Oct 1, 2007 | 08:21 PM
firstrider's Avatar
firstrider
Carbon fiber is over 5K for a roll 125 yards long.I think who ever told you it was cf had too many adult beverages .Am making some carbon fiber pcs. to finish the interior on the FirstRide.Will have the trans cover ,gas tank cover ,tool tray cover, console ,wrap around under the seats in carbon fiber .Have a very talented 35 yr. friend who works at Pratt -Whitney in W.P.B. helping me.Then the FirstRide will be done after 10-14 yrs of work .Will post pics soon.We also made a carbon fiber mold to make the heater boots for '49-'52 Ford & Mercury P.U. trucks equipped with Magic Air heaters.Will be pouring the first one 2nd week in Oct.If any one out there is interested let me know.These are exact reproductions of originals complete with cast marks in the correct places.Am off to Talladega for a fix & then to Tn. to look at some property.The quality of living in Pt.St. Lucie Fla. has taken a dump these last few yrs.Way to many different ethnic groups not respecting the earth and others .Later, Denny
Old Oct 1, 2007 | 11:49 PM
Brian_B's Avatar
Brian_B
Originally Posted by 48fordjeffie
Brian,
Where could I find something on this on the net? I'm not a off roader, I bought this thing for winter driving here in Central N.Y. and if I have to go off road occasionally so be it. It cost too much $$$$ for me to destroy the truck by offroading it, in my humble opinion.
Thanks...
Jeff
Umm...truthfully? There might be some on this site. Is there a 4X4 off-road area specifically around here? Its been a long time since I was into off-road stuff and that was long before I was on this site.
Where I saw a ton of them being made and installed is on an explorer 4X4 site.
If this site does not block the link, I will post it....
https://www.ford-trucks.com/forums/
If the above link goes away when I post...run a search for explorer forum, or serious explorations and you will find the forum.
They typically call them "rock sliders". You may need to run a search for them. I am not sure where the threads are anymore.
They are not hard to make. Some angle iron (or bent plate) for the frame mounts and some tube for the step bars. A torch, grinder, and a welder is all it takes to make them. You need a drill and bolts to mount them.
The finish options are endless. rattle can paint, automotive paint, bed liner (rhino, line-x, etc.), powder coating. They usually rattle can them...since they will be scratched up all time. LOL
Old Oct 2, 2007 | 08:27 AM
48fordjeffie's Avatar
48fordjeffie
Brian,
Thanks for the info. I posted a couple pictures of a piece of the running board in my gallery. Take a look and let me know if you think the sales guy was shoveling you know what my way or not.
Jeff Ford salesman
Old Oct 2, 2007 | 08:38 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Looks like plastic to me....
Old Oct 2, 2007 | 08:53 AM
48fordjeffie
That's what I thought!!!!
Ford salesmen
Old Oct 2, 2007 | 09:02 AM
Brian_B's Avatar
Brian_B
Looks like plastic of some sort. I am certainly no expert though.
Obviously...whatever it was..that is was....it did not take being bumped like that.
Old Oct 4, 2007 | 04:36 PM
Kusto's Avatar
Kusto
I went with the 4" oval ford factory nerf bar style when I replaced my POS plastic junk that came on my F-350 after 3 weeks. I think the oval nerf bars look much nicer than the narrow round ones. The price was similar to the Westin nerf bars.
Old Oct 5, 2007 | 12:30 PM
ToughBuiltFord's Avatar
ToughBuiltFord
FTE Sponsor
Our shop carries a bunch of different nerf bars and running boards made from steel, aluminum, UV-resistant plastic, etc. You can check them out here: http://motorhaven.autoanything.com/nerf-bars/10A50172.aspx
Old Oct 5, 2007 | 03:27 PM
AXracer's Avatar
AXracer
Carbon fiber has a very distinctive weave pattern to it, try an image search on Google for pictures, as said it is expensive and requires special equipment to mold it. It is strong enough that if you did manage to break it most of the pieces would still be "hinged" to the main piece. When fiberglass breaks it leaves a lot of "fuzzy" filaments along the break. Your RB look like it is ABS plastic which is commonly used for parts like this. Some ABS may have some fine fiberglass filling mixed into the resin to give it added stiffness like the better black plastic bed toolboxes that don't sag in the middle.
Summit sells tubular steps for pickups at a good price. My brother bought a set for his new truck from them at 1/2 what the dealer wanted.
jeff1981
Aug 14, 2010 05:50 PM
SteveBricks
S. California Chapter
Aug 12, 2008 11:25 AM
Redmanbob
Mar 29, 2008 06:04 AM
48fordjeffie
2004 - 2008 F150
Oct 1, 2007 02:48 PM
