I have a 5.4L F250 and the passenger side turn signals aren't working properly. When the turn signal lever is held up half way, the turn signals work fine. When the lever is pushed all the way up, only the rear light flashes and it flashes very rapidly. Any advice on fixing the problem would be appreciated. Thanks.
You may need a new Muli-Function switch or MultiPurpose switch which will eventually wear out. They cost around $90 at the stealership if I remember correctly.
Before purchasing the switch however I would check the wiring as well as the bulbs for any corrosion or shorts.
I replaced the switch on my sister 95' Explorer which went bad. My 04' SD takes the same switch/lever as her 95' does.
