Turn Signal Problem
Old Jul 31, 2005 | 09:51 PM
wwfleha's Avatar
wwfleha
Turn Signal Problem
Hi,
My name is Ward. I am a newbie. I have a 2002 F250 SHD 7.3 Turbo Diesel. I am having problems with the turn signals. I checked the fuses and they all look ok. Occasionally when I hit the turn signal lever, the signal might flash. This is the case if I use the right or left turn signal.
I am thinking there may may be a problem in the turn signal device, whether it be the lever or the switch assembly. By the way, all the bulbs are good. I am having difficulty locating the parts on line to see if I can purchase them. I don't want to go to the dealer or garage unless I absolutely have. I really love and enjoy my F250, but every time it goes to the garage for something, it always costs somewhere in the range of 300 - 400 dollars.
So if someone out there can pass along some advice, I would greatly welcome it.
Thanks - - - Ward
Old Jul 31, 2005 | 10:08 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to electrical forum.
Old Jul 31, 2005 | 11:33 PM
Franklin2's Avatar
Franklin2
Does it stay on solid when it doesn't flash? If so, I would replace the flasher unit. Your truck is pretty new, but the older trucks had the flasher unit in the fuse box. One is for the 4-way emergency flashers and the other is for the regular turnsignals.
ehbedard
18
Sep 16, 2015 09:06 PM
HVACTOM
Feb 14, 2015 04:33 PM
orion39
Exhaust Systems
Oct 1, 2007 01:28 PM
turkyhntr
Mar 7, 2007 08:34 AM
4x2Fordman
Dec 18, 2004 09:07 PM
