Sponsored by: Real Truck
2005 F250 Blinker Problem
Old Sep 30, 2007 | 07:19 PM
orion39's Avatar
orion39
I have a 2005 5.4L F250 with a blinker problem. When the passenger side turn signal lever is held up half way the blinkers work fine. When the lever is pushed up all the way only the rear blinker flashes and it blinks very rapidly. Any ideas?
Old Oct 1, 2007 | 11:00 AM
bpounds's Avatar
bpounds
Sorta sounds like the turn signal switch, although I cannot explain the fast blink. Anyway, I'll bump this for ya.
Bill
Old Oct 1, 2007 | 11:42 AM
BIG-FUJIMO's Avatar
BIG-FUJIMO
I had the same problem with my blinkers on my 99 SD and it was because I put LED light bulbs in the taillight I guess it didn't draw enough current. Replaced them w/ regular bulbs and they worked fine. Just make sure the correct bulb is installed. Did it just start doing it or has it done it since you owned the truck?
Old Oct 1, 2007 | 11:52 AM
redford's Avatar
redford
FTE Leadership Emeritus
Sounds like your multifunction switch needs replacing.
............or maybe your blinker fluid is low?
Old Oct 2, 2007 | 05:37 AM
orion39's Avatar
orion39
It just started doing it on Saturday night. I have the original bulbs in it still.
Kris with a K
Feb 24, 2017 03:09 PM
GorrellV10
Modular V10 (6.8l)
Nov 11, 2016 09:35 AM
tufftruck
Nov 10, 2016 12:54 PM
Frozen_Joker
Aug 18, 2016 04:30 PM
confederate_mudder
Electrical Systems/Wiring
Apr 9, 2007 01:29 PM
