Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2003 escape starting problem
Old Oct 1, 2007 | 10:06 AM
pinsbro's Avatar
pinsbro
car does nothing when you try to crank it.power is present with the key in the acc position but loses all power when it is put in the run or start positionall that happens is the gauges jump up for a second please help any ideas would be helpfull. im ready to hit this thing with a hammer.
Old Oct 3, 2007 | 06:01 AM
Ford43's Avatar
Ford43
Don't get the hammer out yet. First thing check the Idle air control valve. A common problem that will lead to a non-start. You can clean but it is so easy and inexpensive to replace. A code scanner can tell you for sure if it is bad but I am guessing that it is a good place to start. Hope this helps.
Old Oct 3, 2007 | 07:00 AM
DoctorCAD's Avatar
DoctorCAD
I think you mean thet the starter isn't turning when the key is turned????
If so, check the cables going to it or the key switch may be bad or the battery may be too weak to turn it or the neutral select switch may be bad (It is in park). There's a bunch of things that it could be
Pick33
Dec 11, 2010 09:08 PM
jeff godfrey
6.4L Power Stroke Diesel
Oct 17, 2010 06:26 PM
pinsbro
Oct 10, 2007 11:01 PM
rocknmud
Apr 18, 2006 12:25 AM
