Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2003 escape starting problem
Old Oct 1, 2007 | 10:01 AM
pinsbro's Avatar
pinsbro
when i try to start the car the gauges jump up and the nothing.it wolnt crank or anything .with the key in the accessory position the radio has power but when you put it in the run position all power is lost .please help
Old Oct 7, 2007 | 10:21 AM
Nitramjr's Avatar
Nitramjr
I hate seeing a thread go unanswered, especially by a new user. Have you resolved your issue yet?
If not, let us know what you have tried so far. If you had it fixed, let us know what it was....
Old Oct 10, 2007 | 10:04 PM
aj7885's Avatar
aj7885
2003 starting problem
Is it possible that this key was cut recent. Or did this key work b4. The Ford uses a PATS key which is a key with a sensor chip in it. If the key is not programmed into the cars electronics (or not a key with a chip in it) then it will not start the car. It will unlock the doors and will turn in the ignition but the car will not turn over.
Old Oct 10, 2007 | 11:01 PM
sfcwoodret's Avatar
sfcwoodret
It may also be possible that the ignition switch itself is going bad.
Psyclopse
May 11, 2015 12:51 AM
mb1096
May 4, 2014 09:04 PM
sth62691
Large Truck
Oct 16, 2011 07:02 AM
BrockwayMT
4 Cylinder Engines
Dec 14, 2004 08:08 PM
