excessive oil consumption
Old Sep 28, 2007 | 10:11 PM
farmer4's Avatar
farmer4
I have a 1995 Superduty 450. It has 117,000 miles. It uses a lot of oil, several quarts per hour of operation. I can not find any leaks. I degreased and steam cleaned the engine, the engine is clean.
It does not seem to smoke either. No smoke at startup or idle.
I would appreciate help on tracking down the cause and cure of the problem.
Old Sep 29, 2007 | 01:09 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Several quarts an hour that isn't leaking and isn't getting burned........I'd have to say injector o-rings. The middle o-ring on the injector could be allowing the oil to pass into the fuel system.
Pull the fuel filter and see what it looks like. If it's as black as oil it may very well be. If it's been doing this for a while you could also pull a sample from the fuel tank.
Old Sep 29, 2007 | 01:13 PM
c00nhunterjoe's Avatar
c00nhunterjoe
x-2 i agree, it has to be goin somewhere, i bet that fuel filter weighs 10 pounds
Old Sep 30, 2007 | 07:52 AM
79_250RangerLariat's Avatar
79_250RangerLariat
Had this happen to an 95 IH bus a few years back, couldn't figure out where 5 gal could go so fast Dipped the tank and it looked more like 2 cyl for the chain saw
Old Sep 30, 2007 | 11:55 AM
c00nhunterjoe
at least you know the injectors have enough lube....
Hopsing69
Jul 10, 2013 07:13 AM
dieselgirl808
Apr 17, 2013 12:05 AM
dreamison
16
Mar 28, 2011 10:10 PM
turtletalk
63
Dec 27, 2009 02:58 AM
BFOOTER03
Jun 6, 2007 04:38 PM
