Original 272 that burns oil
Any advice on where to look on an untouched 272 in a 56 F100 that is burning oil and smokes? Checked the compression and all cylinders are around 60-70 PSI each but all have oil residue on the plugs. I have checked the oil return ports under the valve covers and they are clean. It doesn't smoke that bad at an idle but when I drive it its like I am fogging for bugs. Thanks for the help in advance.
Bing
Bing
on
Valve guide seals are the most likely thing. Although the compression is low. The seals get brittle and crack with age. They can be replaced without pulling the head with an adaper to put air into the cyl to keep the valve closed so as not to drop on the piston while doing it.
Yer oil wiper rings may be stuck also. I recomend an overhaul.
on
Originally Posted by arctic y block
My Y block is in about the same shape in my Fairlane. They make me run in the back of the parades cuz it smokes so bad. As long as they are getting oil to the center main and rockers they will run almost forever.
The motor currently in my truck came from a junkyard. One 113 head, one C head. Rocker shafts were so badly grooved a ruler might have done a fair job of measuring the depth, and of course rockers equally bad. Rods were nonrebuildable. Crank had to have a clean up grind, ending with a 30/50. Bores had to go .080 over. It was a mess, and it ran like that!
Itch71
16
10-04-2016 08:27 AM
bjmayberry2
07-17-2014 09:18 AM
