front axle u-joints
Old Sep 28, 2007 | 08:56 PM
97 RED PSD's Avatar
97 RED PSD
front axle u-joints
Anybody got a step by step for the outside u-joints on a Dana TTB 50? Looking to replace mine but not sure what all tools I might need or steps to take.
Old Sep 29, 2007 | 01:52 PM
97 RED PSD's Avatar
97 RED PSD
So I've got it down to the spindle and I can't get it to separate from the axle. Any tips for this part? Also, I think the retaining key for the wheel bearing might be broken, it came out in two pieces. Anyone know where I can get another one of these?
Old Sep 29, 2007 | 02:14 PM
wreckit72's Avatar
wreckit72
Is this what it looks like?
Old Sep 29, 2007 | 02:22 PM
wreckit72's Avatar
wreckit72
When I did mine I had to drive a chisel in between the spindle and the steering knuckle to get it apart.
Old Sep 29, 2007 | 03:08 PM
c00nhunterjoe's Avatar
c00nhunterjoe
use a ball peen hammer and give her a few good whacks on the center section, not where the bearing rides. she will come off without too much trouble, works like a charm
Old Sep 29, 2007 | 05:39 PM
97 RED PSD's Avatar
97 RED PSD
Any other ideas? Those things are rusted on there tighter than bark on a tree. I don't want to hit 'em too hard on the spindles themselves. Unfortunately I don't have a torch, but I think a little heat might be what they need.
Old Sep 30, 2007 | 06:08 AM
Cuda_jim's Avatar
Cuda_jim
I use a 5 lb rawhide hammer to get the spindle to move. You can really whack it hard and not cause any damage to the spindle. or, Hammer out the studs, they are serrated like a wheel stud. They can be reinstalled after you get the knuckle off.
Old Sep 30, 2007 | 09:44 AM
BadDogPSD's Avatar
BadDogPSD
The outers on the D60 I'm rebuilding were so rusted I had to take out the studs, hit the spindle with a bfh, AND drive a chisel between the spindle and the knuckle before it would come off. If you go the chisel route, be careful and work your way around the edges... tap one in, move over a couple of inches, tap on 2nd chisel in, remove the first, go a couple more inches past where you put the 2nd on in, etc. New spindles are expensive, so you don't want to ding it up too much! Oh, and soaking with PB Blaster might help too. Good luck!
Old Sep 30, 2007 | 09:53 AM
84-250's Avatar
84-250
Go to autozone and borrow their 4WD spindle puller attachment.(it goes onto a slide hammer). Install the spindle tool tightly, and wack away with a sledge hammer. When you break the rust seal, start alternating sides to walk it out, putting chesils on the opposite you are hitting walks it out faster.
Old Sep 30, 2007 | 11:33 AM
c00nhunterjoe
the slide hammer is a good method, i didnt realize autozone carried it, but the hammer has never let me down and while working for the county years ago the trucks were.....well lets just say they werent kept in the best of shape. and after plowing and spreading salt with 'em they werent exactly rust free either
Old Sep 30, 2007 | 11:34 AM
c00nhunterjoe
oh, and no heat, and i dont prefer the chisel as you can take pieces of the hub and spindle off while chiseling
Old Sep 30, 2007 | 12:16 PM
84-250's Avatar
84-250
I tried the slide hammer, it was a 5lb. Then I added a 28lb block of steel to use as the slide hammer and it still didnt help.
Old Sep 30, 2007 | 12:29 PM
c00nhunterjoe
the regular hammer on the spindle has always worked fo rme, hit at different angles..top sides bottom... to breakit loose
Old Sep 30, 2007 | 01:15 PM
97 RED PSD's Avatar
97 RED PSD
That's awesome! Exactly the tool I was looking for. Spent about 3 hours yesterday trying to get them off and had it done in 5 mins after I got that baby! Now I'm trying to get the snap rings out and can't get them to come. Any tips on that? Thanks a ton for the help.
Old Sep 30, 2007 | 01:41 PM
c00nhunterjoe
snap rings on the u-joints can get ugly. i assume they are pretty well stuck, dont waste the time with the pliers till u get them busted loose, its real easy, use a socket, 9\16 or 5\8, place it over the ring and give it a good whack, if that doesnt free it up then use a punch and hit it as though you were trying to spin the clip around in a circle
