erson rollor rockers
Old Mar 7, 2002 | 12:32 AM
jwtimme's Avatar
jwtimme
From my looking around the only true rollor rockers for the FE motors is the erson ones, Am I correct. Also I sent them an e-mail with no reply. I'm wanting to know how much they are and where can I get then. Do I buy directly from erson or from a distrbutor. Has any body had any problems with these rocker.
:-staun
Old Mar 7, 2002 | 09:53 AM
John72_CS's Avatar
John72_CS
Might check out these:
http://www.dscmotorsport.com/asp/Products/popup_PartDetails.asp?PartID=132
Old Mar 7, 2002 | 03:56 PM
FE427TP's Avatar
FE427TP
you might want to make sure that whereever you order them from has a new batch in, the designer for those visited a different FE forum a while ago and got some suggestions and redesigned them to help hold the valvetrain together even better even if there was valvetrain failure that would hurt a engine in the old design
Old Mar 7, 2002 | 08:30 PM
Sunny_in_hollister's Avatar
Sunny_in_hollister
Rocker Arm Specialists makes a full roller setup for the FE motors in aluminum or stainless. The stainless version was featured in a few FE buildups in some of the mags and it is called the Max Roller. They were making these before the Erson rockers came on the market. I also believe that they are the ones supplying Shelby.
Reggie
Old Mar 7, 2002 | 08:38 PM
Sunny_in_hollister
grego
Apr 26, 2007 02:12 PM
gtex
Feb 25, 2005 11:57 AM
sejackson
Jul 2, 2004 09:46 AM
Randyb12
28
Apr 9, 2004 12:41 PM
gtex
Jan 5, 2004 11:03 AM
