Removing adjustable rockers...
Old Feb 24, 2005 | 07:06 PM
gtex's Avatar
gtex
I've got the Erson adjustables rockers/shafts/stands...
Do I have to loosen the adjuster to get the stands off? It seems they are binding on the rocker stand bolts because of the spring loading. But, I was really hoping to leave the adjusters in position....But, I guess I'll have to reset the pre-load etc anyway....
this blows...
Old Feb 24, 2005 | 07:30 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Yep Greg..ya wanna take all the load off the rockers and springs!
Russ
Old Feb 24, 2005 | 07:32 PM
gtex's Avatar
gtex
I think I knew the answer...I just didn't want to hear it...I've got one side off....
Old Feb 24, 2005 | 07:34 PM
RapidRuss's Avatar
RapidRuss
Well good ..Keep us posted on any swamp rats they may run out of there?? LOL!!
Im curious to hear what you find was the problem??
Russ
Old Feb 24, 2005 | 07:46 PM
gtex's Avatar
gtex
driver side is being very stubborn.. nothing is loaded, but it won't come up...
On a good note, this shiner taste great and the shop temp is perfect
Old Feb 24, 2005 | 07:58 PM
RapidRuss's Avatar
RapidRuss
Aww Greg dont rub it in.....I cant drink anything til after I sign the new Proposal for the company tomarrow....and Take a flight phisical....and then it YEEHAWWW!!!
Russ
Old Feb 25, 2005 | 01:50 AM
gtex's Avatar
gtex
Well...I had a few more beers..then went at it with the sledge hammer, I finally got it loose.
Anyhow. I need a new set of Ersons and clean 428 block at .020 over....anybody got some?
Old Feb 25, 2005 | 06:06 AM
RapidRuss's Avatar
RapidRuss
OMG Greg...What the hell did you do?? Or what did you find?? Or are you just BS's use??
Russ
Old Feb 25, 2005 | 08:38 AM
strokster's Avatar
strokster
Dayum, leave the forum for a few weeks and come back to carnage. WTF? Did you find the source of the white smoke?
Kevin
Old Feb 25, 2005 | 09:48 AM
Mike G's Avatar
Mike G
this blows...
I know it's too late, especially after a few Shiners, but turning the crank 45 degrees past TDC "should" remove most load from the rocker assemblies.
--Mike
Old Feb 25, 2005 | 09:53 AM
gtex's Avatar
gtex
The sldege hammer and subsequent comments were meant for your amusement.
I'll get back after those rockers shortly. Then I'll have the intake off and I'll let ya know what I find. I'll try to get the intake off without completely rearranging the gaskets. I'd leak to see where they were reall at...But, that's probably just a dream.
Old Feb 25, 2005 | 11:28 AM
RapidRuss's Avatar
RapidRuss
Oh Greg, I didnt think you to a damn hammer to your pride and joy motor!! I was just reffering to too (what did you do to it) as meaning...you jave known for Quite some time that your linkage was a piece of ****...
Not Ragging on you at all..cause I drove and raced mine with what I felt as a funky linkage...and when I had the trans rebuilt..and Sean talked me into the B&M car shifter...I said DAMN..what a freaking difference!!
I would tell you what Vacuum Modulater I have (what color stripe) but the last guy that asked me..I went out to look...and it had so much road crap on it..I couldnt tell what color it was!! LOL...
Old Feb 25, 2005 | 11:57 AM
gtex's Avatar
gtex
This thing never got elevated to Pride-n-Joy status...It's more of a PITA!
71b17mik
Aug 5, 2009 05:28 PM
tastyklair
13
Oct 20, 2004 04:10 PM
tastyklair
13
Jun 29, 2004 02:52 AM
2speed
Feb 4, 2004 02:47 PM
gtex
Jan 5, 2004 11:03 AM
