cam sensor
Old Sep 25, 2007 | 04:42 PM
xjoedirt55x's Avatar
xjoedirt55x
cam sensor
a buddy told be that his 2000 expedition is running poorly, he took it up to autozone, and he said they told him it is a bad cam sensor or something. has anybody ever heard of that? i am not familiar with all of the goofy sensors now. if anybody can offer any information, that would be greatly appreciated
Old Sep 27, 2007 | 07:17 AM
cr_expyeb98's Avatar
cr_expyeb98
Running poorly means what, stumbles, hesitates, won't idle?? What motor. And why did AZ tech conclude that it was the CAM Sens.
The camshaft sensor controls the PCM signals to the injectors to pulsate. It should run poorly or not at all. I'm no expert, but I thought it worked, or didn't. Test with volt meter on truck with key on, engine not running, to make sure it has battery current to it. If it does, remove it, volt meter set to AC, hook up to connectors, pass metal object over the end to look for fluctuation, if it doesn't fluctuate, it's bad. Replace. If it works, keep looking. This is on V8, 5.4.
Old Sep 27, 2007 | 11:34 AM
xjoedirt55x
i went ahead and replaced it, that was the problem
Stroker4Life
23
May 12, 2008 06:23 AM
Paige Haddock
17
Oct 14, 2005 10:57 PM
Spud
Jul 21, 2003 11:48 PM
myst
Jan 26, 2003 11:53 AM
