Aerostar Ford Aerostar
Transmission - What is wrong?
Old Oct 7, 2007 | 11:48 PM
  #31
bozzzz94's Avatar
bozzzz94
Hello Kingnine-Sorry for just now responding. I had to go into the base today on a Sunday to work and just got home. I'm protecting everyone from Terrorists and missing the football games. Isn't fair. Anyway-I checked on both of the transmissions and they are from 3 L's. Sorry-I know that people have been suggesting tranny's from 4 L's because of them being heavier duty, but if you elect to change your mind let me know. Also, the access I have to tranny's is pretty easy for me to get. Our Salvage yard here (Pensacola-me in Niceville 1 hr. drive) sells them for about 75 and there are always about 4 or 5 4.0 ltrs. around. I could assist you anyway I can as far as that goes. I'm trully sorry for everything. I really want to help you.--Respectfully Boz
Old Oct 8, 2007 | 05:13 AM
  #32
kingnine's Avatar
kingnine
Bozzzz-
Really appreciate it. I have a 4L engine and want to try and go with 4L tranny, especially with what people on here say about A4LD.
Hey sometimes things dont work out the way we plan. Hell, I didn't plan on having my tranny die...
Thanks so much though. If junkyard man isnt full of it, then maybe I will be sucessful. If not, Dad won't get his car back. LOL
Old Oct 8, 2007 | 12:52 PM
  #33
JTHill24's Avatar
JTHill24
I must be missing something here.........
But the transmission book I looked in had the 3.0 & the 4.0
using the same A4LD Transmission.
JaY
Old Oct 8, 2007 | 02:37 PM
  #34
copper_90680's Avatar
copper_90680
Jay:
The A4LD for the 3.0L and 4.0L are slightly different.
Old Oct 8, 2007 | 09:26 PM
  #35
JTHill24's Avatar
JTHill24
How Slight is Slightly?
JaY
Old Oct 8, 2007 | 10:30 PM
  #36
copper_90680
Hi Jay:
Here are the things that came to my mind, but it has been so long since I did both transmissions.
1) Bell housing is different since the backside of the engine is different.
2) Torrington roller bearings instead of washer type bearings
3) An additional friction plate in each of the Overdrive and Intermediate drums.
4) The case itself might even be different, even though I'm not at all certain about this.
All in all, I think that if you would just swap the bell housing, a 4.0L transmission can be put on a 3.0L engine since it's more sturdy. However, the reverse is not recommended since a 4.0L engine would put too much stress on the 3.0L version.
Old Oct 9, 2007 | 01:16 AM
  #37
Bear River's Avatar
Bear River
Former ******
The 4.0L tranny also has studier torque converter.
Old Oct 21, 2007 | 05:20 PM
  #38
kingnine's Avatar
kingnine
Got the tranny from junkyard, got it in, things should be good BUT.....
so a little update. Everyone laugh at Kingnine. Because I was lame, I did not replace the front seal from bellhousing to torque converter. Now it leaks = taking the whole damn thing out again. HA Ha HA!! not funny.
Bought seal puller from autozone, works good for pulling seal out of bellhousing of old tranny, but that one is in pieces. Real easy to access.
Seal puller looks like claw hammer with 2 claws.
Any advise on pulling seal with tranny not pulled apart? I.E. with shaft still sticking out.
Old Oct 21, 2007 | 05:53 PM
  #39
96_4wdr's Avatar
96_4wdr
common problem with junke yard setters, seals harden and crack
rear pump seals are probably shot also.
pump requires special alignment tool. also seal removal requires delicate metal unstaking of old seal rim and restaking of new seal to hold in place
best to take to tranny shop and have a pro put in the seals and pump alignment.
not done correctly with pump or seals damaged is another pull and repair, not fun
thats the correct seal puller, the seals are a one timer. stakes in old seal must be chiseled loose so that the seal comes out easily.
freevan
Jul 26, 2014 02:53 PM
Bob Landry
6.2L V8
13
Jun 17, 2013 05:28 PM
bentcipher
Oct 23, 2010 10:29 PM
ljb
Jul 29, 2006 05:37 PM
