i have a 91 f150 w/302 and e40d. i am not getting any spark from the coil. battery is charged. has a new coil, new tfi module, and new pick-up. am getting codes of 121 and 111. tps is giving a reading of 3v with key in run position and throttle closed. 5v at wot. bad tps but will that cause a no spark situation? need some help please tell me what to check and what the readings should be. i have a test light and ohm-volt meter. just need the instructions and data ranges.
Put your test light on the Ignition Coil, one side should stay on (+ POS) and the other side (-, tach) should flash while cranking, if no does not flash pull out the SPOUT jumper and try again.
Let us know what you find.
thank you very much in advance.
jaime
You apparently have a '91 with a MAF conversion. So, the 121 says the TPS is bad, but the 111 says all is good. The EEC does nothing to the spart during cranking, which is why you can crank the truck with the spout removed for timing adjustment purposes.
Yank the cap off the dizzy, and see if it's turning when you are cranking the engine. If not, you go some serious problems. If so, you have some other electrical problems that the parts you replaced haven't addressed yet.
I had the same problem. What I found was the small ground wire that hooks to the negative terminal lug on the battery was broken loose. I re-established a ground and it started right up. That is a ground for the ECM.
That wire you are talking about will not stop spark.
It will stop the fuel injectors and other solenoids from firing and the fuel pump from running.
thank you guys for the input. i have not been able to work on the truck for a few days. hopefully this weekend i can get to it. but keep sending in the ideas and i will keep you posted on my progress.
one thing i forgot to mention is that the truck is not a maf conversion. also the dizzy does turn.
Like I said above we need to know if you have power to the coil when you turn your key to start and run. This would be the + POS side of your coil, the red wire with a LT Green stripe.
The other side - (NEG, tach) should flash while cranking, if the test light stays on and does not flash then we have a bad switch (Hall Effect Device) in the distributor or TFI Module.
i have 12v at both the tach and pos side of the coil. just as a reminder, the coil is new, the ignition module is new, the pickup in the distributer is new as well. when i crank the engine the tach side does not flash, it just goes dimm. what next my friends. this widow's son needs some help. thanks
I once bought a TFI module for an 87 Crown Vic and it was no good. Running out of ideas like you are, I got another one and it fired right up. However, that may not be the case with yours.
The only ground for the Ignition system is inside the distributor. If who ever replaced the pick-up unit in the distributor did not get it grounded well then you would have about what you have. Check from the battery ground to the ground pin (IGN GND) on the TFI Module with the TFI unplugged. You should get near zero ohms.
well i checked the resistance and it is at 4 ohms from the tfi ground to the negative ground. still no spark. what is next? can the computers be tested? i am really losing my mind on this one. keep it coming and thanks for the help.
