Multifunction Switch
Old Oct 17, 2012 | 12:43 PM
faceman1's Avatar
faceman1
Ok, my dads 2004 Expedition's multifunction (turn signal) switch lever broke off. Getting a replacement switch on order. Question is how do you remove the column cover to access the switch? I removed the screws holding the two pieces together but can not get it to come apart. Do I need to remove the steering wheel inorder to remove the column cover? Any help would be appreciated.
Thanks,
Jaime
Old Oct 17, 2012 | 04:00 PM
projectSHO89's Avatar
projectSHO89
Disconnect the battery negative cable.
Remove the tilt lever, if equipped.
Remove the ignition key cylinder.
Remove two or three screws that hold the lower and upper shrouds together.
Remove lower cover.
Tilt wheel all the way down and work the top cover out.
Assembly is the reverse.
Old Oct 17, 2012 | 04:07 PM
alloro's Avatar
alloro
The two halves have little tabs that lock them together along the seams. Just grab near a seam and push and pull the top and bottom halves while pulling them apart. This is a brute force procedure.
Old Oct 18, 2012 | 03:17 PM
Moto Mel's Avatar
Moto Mel
I don't believe I had to remove the ignition lock to do the job.
dangrimsley
1997 - 2003 F150
13
Mar 26, 2013 04:20 PM
fordinmudd
Mar 4, 2011 01:36 AM
pressureelite
1997 - 2003 F150
Jul 7, 2010 03:40 PM
dfishrmn88
1997 - 2003 F150
Mar 2, 2006 04:50 PM
t2theworld
1997 - 2003 F150
Oct 26, 2004 11:56 AM
