inturnally balancing a 428
Old Apr 5, 2002 | 02:27 PM
leadmic's Avatar
leadmic
I've heard of internally balancing a 428 can any one tell me what this intells and what the cost would be for somthing like this ?
The problem is the only sorce I've been able to find for a flex plate takes a 390 plate and welds on a weight. They are not very careful and they get it too hot and distort the ring gear. Ive installed two of them and had starter problems with both. I took them off and turned them on a brake lithe and you can see the distortion both side to side and up and down right where the weight was.
thanks for any help Leadmic
Old Apr 6, 2002 | 08:56 AM
dinosaurfan's Avatar
dinosaurfan
Mic, it will cost you between 150-200$. The crank, rods, and pistons all have to be out of the block and get weighed. Then your balnce guy adds heavy 'mallory' metal where needed to balance the assaembly in the pan. Then you need a 390 flywheel and a 390 Dampner. But if your local guys can't balance a flexplate, they probaly can't do this. Why not just buy a 428 'plate to start with ? DF
Old Apr 8, 2002 | 01:47 PM
leadmic's Avatar
leadmic
Hey, DF I cant find a 428 flex plate except through the aftermarket and the one they sell is the one I was talking about. If you know of a factery new or used in good shape for a reasionable price let me know.
thanks leadmic
Old Apr 8, 2002 | 01:55 PM
karlsd's Avatar
karlsd
Autozone sells them for $65.
Old Apr 8, 2002 | 08:45 PM
leadmic's Avatar
leadmic
(The problem is the only sorce I've been able to find for a flex plate takes a 390 plate and welds on a weight. They are not very careful and they get it too hot and distort the ring gear. Ive installed two of them and had starter problems with both. I took them off and turned them on a brake lithe and you can see the distortion both side to side and up and down right where the weight was.)
The two that I tried were susposed to be for a 428 but were for a 352-427 with a weight welded on them they were aftermarket (like the ones you would get from auto zone). The factory 428 flex plates were not solid (like the ones you would get from autozone) they had holes in them.
thanks Leadmic
Old Apr 9, 2002 | 10:22 AM
1QUICK75's Avatar
1QUICK75
J ballan
Jan 17, 2017 09:18 AM
olderford76
New Member Introductions
Sep 14, 2015 11:21 AM
Purely Ford
18
Nov 24, 2004 12:46 AM
leadmic
Jul 2, 2002 11:36 PM
leadmic
Apr 11, 2002 06:36 AM
