300 to 351
Old Sep 22, 2007 | 10:56 PM
86step's Avatar
86step
300 to 351
Ive got an 86 f150 with a straight six 300 and a np435 4 speed. to swap to a 351 would i need a new transmission, bellhousing, or what?
Old Sep 22, 2007 | 11:39 PM
Wild Karrde's Avatar
Wild Karrde
I'm almost certain all the transmissions for the 300 I-6 will bolt directly up to any Ford small-block, including the 351W.
If I'm wrong, someone else will be along shortly to correct me.
Old Sep 22, 2007 | 11:46 PM
86step's Avatar
86step
does it matter whether the 351 was set up with a manual or automatic?
Old Sep 22, 2007 | 11:49 PM
Wild Karrde
Yes it does, but only in the difference between a flywheel and a flexplate. Manual transmissions have a flywheel, that connects with the clutch from the manual tranny. The auto has a flexplate that the torque converter bolts directly to.
If the 351W has a flexplate, and you want to keep your manual tranny, all you have to do is find a 351W flywheel. They're available at any parts house, or used at a salvage yard (though I'd buy it new).
Be a good time to put a new clutch assembly in as well, since you'll already have it apart.
Old Sep 23, 2007 | 10:05 AM
clunker86's Avatar
clunker86
the 300, 302 and 351w all share the same transmission bolt patern and will all work together. the biggest thing is to know is that the flywheel can not be swaped from one or another. i believe 83 and down used a 28oz counter weight and 84 and up used a 50oz counter weight. the 300 did not use a country weight on the flywheel because it was internally balanced. hope i got this right. you will know when you go to start it. if its right or wroung. it will have the shacks and can scwer an engine up.
Old Sep 23, 2007 | 01:34 PM
Franklin2's Avatar
Franklin2
Look to make sure the 351w has a drilled hole in the back of the crankshaft(it should). Being it was on an automatic, it probably doesn't have the bushing or bearing that slides in. You need to install this bearing since it supports the tip of the manual tranny input shaft. It's called a pilot bushing or bearing.
You will also have to grind the motor frame perches off your truck, and get some v8 ones and bolt them in, so the rubber motor mounts will work.
Old Sep 23, 2007 | 11:05 PM
86step's Avatar
86step
thanks for all the advice. the reason im considering the swap is that whenever i hit a hill that needs a lot of gas to go over, the motor starts this really loud squealing-snapping sound and i can't figure out whats doing it. Any ideas?
Old Sep 24, 2007 | 01:16 PM
Franklin2's Avatar
Franklin2
The bolts that hold the carb together are famous for coming loose on these engines. I would take the carb off and have a look.
Old Sep 24, 2007 | 01:26 PM
dragogt's Avatar
dragogt
there's, a guy on the big bronco forum doing the exact same thing only in reverse. here's link for ya https://www.ford-trucks.com/forums/6...00-inline.html
snakedoc
Aug 4, 2011 10:10 PM
wildjon300ci
Nov 13, 2006 12:55 PM
cbracing17
Engine Swaps
Oct 3, 2005 07:37 AM
beratte
Aug 15, 2001 09:43 PM
bigfordman70
1978 - 1996 Big Bronco
May 26, 2001 09:01 PM
