On my 94 F150, the air bag light continually blinks in this pattern...1-2-3...1-2
And again 1-2-3...1-2
Driving down a washboard road I believe started this. What needs to be done to eliminate this problem?
Thanks to all who post a response.
That is code 32, more than likely you have a broken Clockspring in your column.
Does your horn work?
yes I would say clock spring. I have the same problem with my Aerostar. So My horn does not work and no cruise control. The clock spring from Ford is around $160.00 cdn. here in Canada
Order from either of the 2 sponsers, Y2K or Direct Ford Parts. The value of the US dollar & the Canadian Dollar are equal this week. Should be less than a $100.
Is it so important to have a good clockspring? To me it doesn't affect my driving at all. I only use the horn perhaps once a year when my wife's late getting to the truck for church mass. And the airbag is intact. Can I find and install a used one?
$100 or $160 is a lot to pay for something that doesn't affect driving.
Thanks for your input, guys.
let me know if you need any of these parts im swaping my air bag column to a non air bag set up. im short and truck is mainly off road use. so ill have the whole assembly if you need any part minus the ignition. sorry lost the key so that had to be broken
