Wont Start....HELP!!!!
Old Sep 21, 2007 | 11:37 AM
The Grand Pooh-Bah's Avatar
The Grand Pooh-Bah
Cool Wont Start....HELP!!!!
Got down to the mid 30's this morning and now my truck won't start. The "Wait light" comes on then goes off like normal. I turn the key and it cranks but wont start. Tried numerous times.
HELP
99 7.3
Old Sep 21, 2007 | 12:03 PM
WonderDonkey's Avatar
WonderDonkey
Check the Battery, unless you have 10.5V it wont start. it will crank but it does not have the power to run all the modules. do you have a mulit meter
Old Sep 21, 2007 | 12:34 PM
The Grand Pooh-Bah
12.25 volts
Old Sep 21, 2007 | 12:43 PM
WonderDonkey
is it 12.25 volts? i always thought it was 10.5 See you learn somthing new everyday
Old Sep 21, 2007 | 02:04 PM
HKusp's Avatar
HKusp
I think he is saying that he checked it with a meter and it has 12.25 volts so it ain't the batteries.
Old Sep 21, 2007 | 03:51 PM
WonderDonkey
I got you, I am sorry i mis understood.
Old Sep 21, 2007 | 03:52 PM
WonderDonkey
When you check have someone try cranking it and see where your battery goes from there. Also when your cranking does your tach move at all?
Old Sep 21, 2007 | 04:59 PM
The Grand Pooh-Bah
Looks like it is the glow plug relay. With key off had power to one lug on relay. With key on had power to one additional small lug. The relay should have sent power to the second large lug when the key was turned on but it didn't. Bye the way. Now that it has warmed up outside it fired up like normal.
Old Sep 21, 2007 | 05:30 PM
WonderDonkey
cool sounds like you got it
