Sponsored by: Auxito
Is this a vacuum issue?
Old Sep 27, 2007 | 08:26 PM
Silver Streak's Avatar
Silver Streak
That's because vacuum is more accurately a function of engine load. At idle most engines are in the vicinity of 20 in-Hg vacuum in the intake manifold. At roughly 10 in-Hg they are sending about half of the available power at whatever rpm they are at to the wheels. Most power accesories stop working at around 10 in-Hg, so if you're over 1/2 throttle nothing that uses vacuum will work. It takes several seconds for the vacuum in the system to bleed off and that's why you don't see the affects immediately.
Old Sep 28, 2007 | 05:27 AM
minnesotakim's Avatar
minnesotakim
That's good info, I am thinking I must have a small leak somewhere in the system. you say it should affect the heat in the same way?
Old Sep 28, 2007 | 07:40 AM
Silver Streak
It typically does, but I can't say for sure that it would because I've never seen first hand how this problem affects these trucks.
auric
29
Jul 24, 2024 05:16 AM
eodtek32
Jun 7, 2014 08:04 AM
ddiercks
Jul 13, 2013 06:00 AM
Nick Greer
Aug 2, 2012 08:28 PM
blgrable
Aug 29, 2004 03:53 PM
