Vacuum canister question.
Old Jul 30, 2012 | 10:05 PM
Nick Greer's Avatar
Nick Greer
When I bought my 73 F100 with a 390, the vacuum canister was disconnected and bypassed with a "T" fitting (the third line was plugged on the T). I have since reconnected the vacuum canister. Since doing so, I've fixed quite a few problems, but I think I'm having some of my rough idle issues due to a vacuum leak. All open connections have been plugged, so my question is as follows: Can I bypass the vacuum canister and have no problems? All of the emissions junk is disconnected, and it has factory air. The A/C would actually blow through the panel and floor vents before reconnecting the can o beanz, but now it only blows through the top vents on the dash, no matter what the settings are...of course, it's not blowing cold air, but it's at least moving some air when normal.
Just wanted to know if bypassing the canister would have any negative effects?
NG
Old Jul 30, 2012 | 10:13 PM
ChiefM's Avatar
ChiefM
Nick,
Usually the can is what helps the A/C move the vent openings, sounds to me like you may have the can connected wrong.
Please feel free to join us on the Georgia Forum !!!!!
Georgia Chapter - Ford Truck Enthusiasts Forums
Old Jul 30, 2012 | 10:18 PM
Nick Greer's Avatar
Nick Greer
Okay...before, when it was bypassed, the AC would blow in the proper location (vent, panel, floor). When it's reconnected--no dice. Is the canister a one-way canister? If so, I'll try swapping the lines. It's rather loose, kinda rattles around a bit, and I wonder if it might not have a crack in the canister or a hole, leading to a vacuum leak.
Will bypassing the canister have any adverse effects?
NG
Old Jul 31, 2012 | 07:13 AM
fmc400's Avatar
fmc400
MSEE
If you get rid of the canister, all your heater/AC controls will let go at wide open throttle when vacuum is low. It's supposed to be connected to the system through a 2-to-1 check valve along the firewall.
If your heater is effectively stuck on defrost, then that means you're not getting any vacuum out of the selector switch. This is caused by vacuum not being hooked up, or a bad switch. Reconnecting the canister is not going to fix the issue you're having because vacuum is high enough at idle anyway and the canister is effectively transparent because of the check valve in that instance.
Old Jul 31, 2012 | 10:20 AM
Nick Greer's Avatar
Nick Greer
Cool. Where is the vacuum check valve usually located? The PO disconnected a ton of vacuum lines and bypassed most everything. A lot of vacuum fittings weren't even capped off, been capping them, took the canister bypass out, and now it's stuck in defrost.
Old Jul 31, 2012 | 10:49 AM
400 .040over's Avatar
400 .040over
should be around teh brake boster area.
mikeo0o0o0's Avatar
mikeo0o0o0
Here are a few illustrations from the Ford parts catalog, maybe they'll help you some with the A/C.
Click on the .pdf links to view.
File Type: pdf
File Type: pdf
File Type: pdf
Old Aug 1, 2012 | 08:04 PM
Nick Greer's Avatar
Nick Greer
Found the vacuum leak...
So I found the vacuum leak...turns out it is my soup can/can o' beans vacuum reservoir. I'm gonna be replacing it soon, until then, I'm probably gonna bypass it. Thanks to everyone for your help. It's amazing how smooth the engine idles when the vacuum reservoir is out of the loop and bypassed--that vacuum leak reallllly messes things up on the idling side of things.
NG
Old Aug 2, 2012 | 01:05 AM
mr.fordneck's Avatar
mr.fordneck
On my 90, my coffee can looking vacuum canister helps run the heat and AC. I bypassed it at the fitting when it got a rust hole. No noticeable performance difference but the climate controls were weak. But that was in the fall when I use neither the heat or AC anyway. I replaced it with a new used one and my system has plenty of vacuum
Old Aug 2, 2012 | 08:28 PM
texanrick's Avatar
texanrick
I don't want to beat a dead horse and not sure if I should start a new thread but...after reading this thread I don't have a canister on the right side of the engine as shown in the parts breakdown but I did have one on the left which was long since removed. My A/C sounds like some of the vents are closed. Full fan with nothing coming from the vents. I'm trying to fix without taking the cab unit apart. I have a '77 F150 Ranger with a 400. Any photos out there with factory AC? I know I'm missing some parts.
jtexfisher
21
Jan 26, 2014 04:38 PM
xc4jokestomper
21
Jun 18, 2011 07:11 AM
ivorycruncher
May 19, 2007 12:01 AM
wildjon300ci
Oct 9, 2002 03:14 PM
JBronco
1978 - 1996 Big Bronco
Nov 16, 2001 08:50 AM
