question for gtex
Old May 19, 2002 | 01:56 PM
MufassaMaxx's Avatar
MufassaMaxx
question for gtex
What dynomax headers do you have? I'm looking at their lower budget set for $215. They're Jet-Hot coated and i've heard good stuff about that coating but what can you tell me about these headers? I'll use them for a 67 f100/ 352.
Good/ Bad?
fit/finish?
thanks
Nate
Old May 19, 2002 | 02:29 PM
hotrodford_88's Avatar
hotrodford_88
question for gtex
I can pass on this little piece of advice for anyone planning to use the Dynomax headers on a 65-66 with a 390. They didn't fit my truck period, even though they said they did. I had problems with them hitting my Motor mount stands, and they came out right ahead of the transmission crossmember, which would have resulted in a sharp bend or pinch in the exhaust at the collector.
Also, if you're running an automatic, watch out for the column shift linkage, mine was sitting right below the linkage and I couldn't even get the transmission out of park. Boxed mine up & sent them back.
Buying a set of Heddmans as we speak.....
Kyle,
Dayton, Texas
Old May 20, 2002 | 03:05 PM
gtex's Avatar
gtex
question for gtex
[updated:LAST EDITED ON 20-May-02 AT 04:06 PM (EST)]Hola,
Many headaches with the Dynomax ceramic coated headers for my 69 F250 2wd with a 390. The driver side exhausted into the tranny linkage as mentioned above and the driver side piping had to be mangled to accomodate the power steering unit. While trying to bend the header exhaust away from the linkage (I also reversed the linkage bracket at the C6), we bent the collector flange so I ended up welding straight to the headers. This is a bit ugly with the ceramic coating. I still have significant leaks at the header gaskets. Overall, not a good fit. I believe the finish is acceptable. I would go with some of the other reccomended headers. I believe this is one of those times when saving some $$ just becomes a PITA!
Old May 20, 2002 | 08:11 PM
FE427TP's Avatar
FE427TP
question for gtex
My Hedmans didn't fit very well, neither did the set I helped a friend put on his truck but it was just bellhousing clearance on the passenger side
Old May 20, 2002 | 09:42 PM
Ratsmoker's Avatar
Ratsmoker
question for gtex
nates78
Feb 14, 2011 10:45 AM
Nate_64
19
Aug 18, 2009 06:49 PM
Studenut65
Modular V10 (6.8l)
25
Apr 16, 2006 04:32 PM
learpilot
24
May 25, 2005 08:59 AM
MufassaMaxx
Apr 16, 2002 10:05 AM
