Just registered on the forum after running google serach to try and find some answers.
Just bought an '84 F250 Supercab 4x4 with power windows and locks. Need to replace passenger side window after it shattered. Getting a replacement window from the junkyard and wanted to know the procedure. Are there any special tools needed? One of the generic repair manuals said that the visor window had to be removed before a new window could be installed.
1.remove door panel
2.remove vent window (2 phillp screws on top and 1 bolt thats about even with the door handle)
3.remove window from its lift track
4.install new window and lower all the way down
5.install vent window
6.install door panel
