Window Motor Interchange
Old Mar 11, 2007 | 01:59 PM
93f1505.0L's Avatar
93f1505.0L
I have a 93 f150 reg cab. The Drivers side window motor makes a lot of niose when you use it. It works fine going up and down but makes alot of noise. I allready replaced the rubber bushings in the gear with 1/4 nuts about 6 months ago becuase they wore out. It just started making the noise last week. I have a window motor for a 94 f150 but it is for the passenger side and was wondering if it would work on the drivers.
Thanks
John
Old Mar 11, 2007 | 02:33 PM
lostin90s's Avatar
lostin90s
I thought they were side specific. L R . But just check out numbers at Ford it won't cost you and you'll find out if same or not. Good luck
Old Mar 11, 2007 | 02:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Right and left window motors will not interchange. (Ford basic part number: 23394 Right; 23395 Left). The window motors gear kits are the same from 1970 thru the 1990's, and are the same R/L, and are available at parts houses as well as dealers.
D0AZ-62234A24-B Gear Kit, Power Window Motor.
There are two types of these kits...the one I listed is the late kit.
The early kits only fit 1965/69 cars.
Old Mar 11, 2007 | 03:05 PM
quicklook2's Avatar
quicklook2
even within some of these years they list more than one motor.
and yes, they are side specific.
Old Mar 12, 2007 | 10:39 AM
93f1505.0L's Avatar
93f1505.0L
Ok Tanks. I figured they wern't. The motors aren't too expensive so Ill just get a new one any how. Thanks for the help. When I first got my truck the window jumped becuase the bushings were broke so I got the kit and replaced it then 8 months later that kit went out so I just replaced it with the nuts.
Thanks
John
eenyok
Aug 19, 2016 08:58 AM
crazed87bronco
May 11, 2012 10:12 AM
1997 F-150
South Carolina Chapter
Oct 1, 2010 06:52 PM
66ca
Jun 13, 2010 02:30 PM
dallej88
Oct 31, 2006 10:29 AM
