Sponsored by: Auxito
Bank 1 running lean
Old Sep 18, 2007 | 11:03 PM
bighibbi's Avatar
bighibbi
Bank 1 running lean
The service engine light is on and the code says that the heated o2 sensor is not working and that it is running lean on bank 1. I have replaced the o2 sensor and it still is throwing the code. Any tips?
PS. It gets horrible gas mileage.....about 9mpg.
Old Sep 18, 2007 | 11:51 PM
ford2go's Avatar
ford2go
I'm far from an expert, but there may really be a lean condition in bank1
- leak in intake manifold
- clogged or dirty injector(s)
- other stuff that the smart folks here know about
As for the O2 sensor, is the code telling you about a bad sensor or a bad heater?
In any case, it could be a wiring problem. O2 sensors are supposed to read around 0.9 v, but it's supposed to switch as the computer adjusts the mixture . I don't know what voltage should be on the heater (probably 12v).
One thing that might explain both issues us a crack in the exhaust manifold.
This could make the O2 sensor read out of range lean. Depending on what
the value is, it could also report as a lean bank.
fordfuelinjection.com has a lot of info on how the systems work.
Good luck,
ford2go
Old Sep 19, 2007 | 08:17 AM
projectSHO89's Avatar
projectSHO89
"Lean" codes
"Lean" codes do NOT mean the engine is running lean, it usually means it's running RICH. That's why your fuel economy has gone down.
Lean codes indicate the computer has maxed out the fuel trim (excessive fuel) but the O2 sensor still shows the exhaust is still leaner than it should be.
Almost ALWAYS caused by an intake leak or an exhaust manifold leak - anything that allows unmetered air in before combustion or exhaust out before measurement.
Lean codes are almost NEVER due to faulty O2 sensors.
Lean codes on both banks are usually due to a vacumm leak in the intake tract common to both banks or a dirty/faulty MAF sensor. The PCV hose elbow is, by far, the most common reason.
Always post the exact DTC, not just descriptions. SEARCHing for the DTC code(s) will usually find previous discussions that will answer your question before you even ask the members.
Steve
Old Sep 19, 2007 | 04:51 PM
drakul20us's Avatar
drakul20us
I was running lean in both banks myself and was also getting terrible mileage. ALso changed all my O2 sensors. It was indeed a vacumm leak in my intake. Like some other fellas here suggested take an unlit plumbers torch to the intake with the truck on, if there's leak, you will hear the engine rev up a bit. Also, clean the MAF sensor
Old Sep 19, 2007 | 06:31 PM
bighibbi's Avatar
bighibbi
Where was the leak? and how much better did your gas mileage get?
tvans63
1997 - 2003 F150
May 4, 2010 08:34 PM
03scf250
General Automotive Discussion
Oct 4, 2009 06:58 PM
davisenvy
Dec 10, 2008 09:54 AM
JDHolland
1997 - 2003 F150
Jan 19, 2008 06:58 PM
mike b
Feb 26, 2003 07:31 PM
