Trans fluid leak
Old Sep 18, 2007 | 05:53 PM
hartski's Avatar
hartski
Trans fluid leak
While traveling from Memphis to Chicago this weekend I had an unusual leak. Trans fluid was being pushed up the speedo cable & leaking from under the dash onto my feet. I noticed the fluid level was a little high, put it's still an odd scenario. It's a 1972 F-100, 302 C-4. A vent problem maybe? Any input would be appreciated.
hartski
Old Sep 19, 2007 | 08:49 AM
blue68f100's Avatar
blue68f100
But being over filled I would lower the level and see if it still does it. Almost sounds like the C4 is building up pressure and forcing it up the cable. Check to make sure the vent is not plugged up. It should look like a metal cap ( 3/8"). This should be loose a free of dirt and grease. I think there is a seal on the speedo drive.
Old Sep 19, 2007 | 04:10 PM
hartski's Avatar
hartski
Will do.
hartski
Cancotree
Large Truck
Dec 4, 2016 11:13 PM
F350dog
Dec 12, 2015 03:26 PM
99FORD EXPY.
6.7L Power Stroke Diesel
Jun 30, 2013 03:39 PM
hartski
Aerostar
Jul 30, 2012 01:21 AM
hartski
Mar 10, 2010 10:11 AM
