Modular V10 (6.8l)
V10 Coolant Change
Old Sep 18, 2007 | 12:54 PM
gokart2's Avatar
gokart2
V10 Coolant Change
I have a Motorhome on an F3 (1999) chassis with a V10 engine. Not sure if it has ever had coolant changed. Can't find a radiator cap to refill radiator! Anyone had experience in changing coolant in models such as this? Any suggestions. Thank you for any pertinent information.
Old Sep 18, 2007 | 01:22 PM
dkf's Avatar
dkf
Newer Ford vehicles do not come with caps on the radiator.
The actual pressure cap is on the coolant resivoir.
There should be a petcock on the bottom of the radiator for draining.
Old Sep 18, 2007 | 05:16 PM
Big Orn's Avatar
Big Orn
So far dkf has given out some good info. That BS Meter is reading in the RED, but it ain't so. Good advice and I'll scoot you a kudos for it.
Old Sep 19, 2007 | 06:42 AM
MarkMoore's Avatar
MarkMoore
I actually saw this post in the Excursion forum yesterday. It's doesn't (exactly) say if its for the V10 or 7.3, but it out lines everything very well and other than a difference in fuild capasicity, there shouldn't be a difference.
Old Sep 19, 2007 | 08:14 AM
lswartz's Avatar
lswartz
I always pull the hoses off as well just to get all the old fluid/flush out. dkf is right on about the coolant reservoir.
draboo
Oct 3, 2016 09:47 PM
Aune163rd
1983 - 2012 Ranger & B-Series
Sep 5, 2016 11:42 PM
jjclkc
13
Jul 5, 2016 03:34 PM
sudsmcduff
Mar 26, 2016 04:13 PM
huskyfan68
May 21, 2015 11:23 AM
