Routing Heater Hoses
Old Sep 17, 2007 | 08:41 PM
870's Avatar
870
1987 F-150 4.9L.
Took off both heater hoses at the same time. Can someone look & tell me where the hose coming out of the water pump hooks up to. Is it the side closest to the fender or furtherest from the fender.
Does it really make a difference?
Thanks, James
Old Sep 17, 2007 | 09:01 PM
quicklook2's Avatar
quicklook2
the one from the thermostat goes to the driver side.
the water pump one goes to the pass. side.
i hope that is clear.
Old Sep 17, 2007 | 09:21 PM
870's Avatar
870
Thanks, James
Old Sep 17, 2007 | 09:23 PM
bradshaw6243's Avatar
bradshaw6243
Old, but not too old
But actually, does it matter which one goes where?
Old Sep 17, 2007 | 09:34 PM
radialarm's Avatar
radialarm
I don't think it does. I've hooked them up either way and they worked. It just flows through with no check valves.
Old Sep 17, 2007 | 09:43 PM
netscaner's Avatar
netscaner
I think coolant should flow in at the bottom and leave at the top to keep it purged of air pockets.
Old Sep 17, 2007 | 10:06 PM
quicklook2's Avatar
quicklook2
the ford service manual says to do it this way.
others who had air in the core or low heat output switched the hoses and it helped.
Old Sep 17, 2007 | 11:09 PM
bradshaw6243
10-4, I agree with in at the bottom and out at the top. With the hose connections side by side, I just did not think about the internal routing of the piping. In at the bottom and out at the top it should be!!!
Old Sep 19, 2007 | 07:34 PM
EPNCSU2006's Avatar
EPNCSU2006
Both of the tubes attach at the top in the exact same way as each other, so it really should not matter which hose goes where. If for some reason it doesn't work, swap the hoses and see what happens, but from a physical standpoint, there is no difference in the two tubes on the heater core.
Old Sep 19, 2007 | 07:53 PM
quicklook2's Avatar
quicklook2
that is untrue.
one is an inlet and one is an outlet.
Old Sep 19, 2007 | 08:07 PM
EPNCSU2006's Avatar
EPNCSU2006
And they are both the same, so there's no way to tell by looking at the heater core, which is which.
Old Sep 19, 2007 | 08:24 PM
quicklook2's Avatar
quicklook2
believe whatever you want then.
ford service manual says one in inlet and one is outlet and that is good enough for me.
Old Sep 19, 2007 | 09:16 PM
EPNCSU2006's Avatar
EPNCSU2006
I'd hook them up like Ford says, but I'm just saying that it probably won't cause any ill-effects if it was hooked up backwards.
Old Sep 20, 2007 | 04:04 AM
eco's Avatar
eco
If you use Ford's factory formed hoses and plumb it up you have an inlet and an outlet and it's self explanatory which is which but if you replumb it you can hook it up any way you want and it would make no difference. Think of the heater core as a continuation of the heater hose with some fins on it.
firstrider
Mar 12, 2015 12:45 PM
tomrflorida
Dec 11, 2014 03:27 PM
04badford
1983 - 2012 Ranger & B-Series
Aug 12, 2014 07:46 PM
teknofile
Jan 27, 2013 08:57 PM
DKW 86
Dec 31, 2010 05:04 PM
