Diagnostic connector???
Old Sep 17, 2007 | 05:44 PM
wd13's Avatar
wd13
Hey all, I've got a 97 F-350 with the 460. I bought a Superchips tuner for it but cant find the diagnostic connector. Where is this thing?? All I can find under the hood is the eec test plug? Under the dash, nothing. What gives?
Old Sep 17, 2007 | 06:40 PM
subford's Avatar
subford
You will not have one under the dash, the EEC test connector under the hood is all you have.
I think you are looking for the covered up test plug on the back end of the PCM computer.
Just pull out the PCM computer and plug it into the back end of it (after you remove the screw and plate).
Then put the PCM computer back in if it will fit with that thing on the back of it.
Old Sep 17, 2007 | 06:47 PM
wd13's Avatar
wd13
I tried the test connector and the plug doesnt fit at all. Didnt know there was a pronged plug on the PCM!?!
Old Sep 17, 2007 | 07:04 PM
subford's Avatar
subford
It is a card edge connector.
Old Sep 17, 2007 | 07:19 PM
wd13's Avatar
wd13
Meaning it would only take a chip right? I dont think that would work for what I'm trying to connect if its like all the others I've been into.
Old Sep 17, 2007 | 07:31 PM
subford's Avatar
subford
No it takes a card edge plug.
I do not think you can use what you have.
Old Sep 18, 2007 | 08:30 AM
Conanski's Avatar
Conanski
Send the Chip back for a refund.. it's a waste of money with the EEC-IV system. Get a timing light and advance the base timing a couple degrees, then drive the vehicle up some hills at hwy speeds and put a sustained load on the motor(lugging at low rpms, not reving). If there is any audible pinging upgrade to the next grade of fuel or retard the timing a degree, and repeat. This and some auto tranny recalibration is all the tuner chip would have done.
Old Sep 18, 2007 | 10:00 AM
tomtoc's Avatar
tomtoc
i assume he's looking for the OBD 2 port, just like i was on my truck. been discussed a few times that OBD2 is 96/97 & up cars and *LIGHT* trucks. 250s & 350s are not light.
...if that's the connection he's looking for
exranger06
1978 - 1996 Big Bronco
Dec 2, 2013 03:46 PM
Nitro Blazer
Feb 28, 2012 01:15 PM
drjoe171
Nov 12, 2010 09:22 AM
ekelly
Dec 17, 2003 04:20 AM
screwy
Mar 6, 2003 08:05 PM
