Burning oil suddenly?
Old Sep 17, 2007 | 01:14 PM
97squarebody's Avatar
97squarebody
Hello all;
I am having a problem with my truck, it is now wanting to burn oil when I pull. I have a 97 with a 460 and a stick. I pull a 10,000 lb fifth wheel with it regularly. The truck has around 90,000 miles on it and has been well cared for. The last trip I took I burnt about a 1/4 inch on the dip stick in 300 miles.
Any ideas as to the cause?
Additional Info;
1. Generally I tow in 5th with the stick. A mechanic friend recomended 4th as it would be better for the motor and trans.
2. I recently had a O2 sensor go bad on a trip. I was just happy to get home with 5.5 mpg. Could I have damaged something?
3. I think it is entering Via the intake due to heavy oil residue in the "rubber tube" that goes to the throttle body. This is after the enterence of the crank case vent.
I am currently running Mobil 1 10(or 15) w50 oil.
Thoughts????
Old Sep 17, 2007 | 01:34 PM
69-highboy's Avatar
69-highboy
Assuming well cared for also means that it wasn't overheated, my bet would be on the valve stem seals. Heat and age will take them out, and any added sludge trapped in a oil return hole let alone part of the seal itself, only compounds the problem.
First things first tho -a compression, or better yet, a cylinder leakage check. This will get to the root of your blow bye issue.
Old Sep 17, 2007 | 02:24 PM
97squarebody
The problem apears only when towing. Running around town, it is fine. You are correct, the truck has never been overheated.
Old Sep 17, 2007 | 03:32 PM
Bear 45/70's Avatar
Bear 45/70
If it ran that rich you could have scored some cylinders which had the oil washed off or even stuck a ring or two. Compression test.
Old Sep 17, 2007 | 04:00 PM
79superduty's Avatar
79superduty
I tore a bunch of those motors apart and 8 out 10 were bad valves .Iwould check there....
Old Sep 17, 2007 | 06:16 PM
Bear 45/70's Avatar
Bear 45/70
A compression test will show either bad rings or valves. A a little squirt of oil will tell you which it is.
Old Sep 17, 2007 | 06:24 PM
69-highboy's Avatar
69-highboy
One might think that towing would build extra heat and with slightly worn parts burn more oil, but I still think it's a valve guide issue. Why? Towing with a stick, especially when decelerating, will raise and hold manifold vacuum high causing the engine to drink more oil.
Go out, hit 65MPH, dump it in third with your foot OFF the throttle and look for the smokescreen in the mirror that is sure to be following you. The higher the revs, the more oil you'll be pullin' in.
Old Sep 17, 2007 | 07:31 PM
Big Blue 87's Avatar
Big Blue 87
My 460 has almost 190000 on it. I am never under 12000 GVW with it. If I keep the RPMS down I use no oil. If I rev it up I can use a Qt. in under 100 miles.
Old Sep 18, 2007 | 10:52 AM
trinogt's Avatar
trinogt
That's very interesting; I wouldn't have thought about that... Maybe that's another reason automatics are recommended for towing over manuals?
(not that I ever abided by the warning! lol)
1969furd
2004 - 2008 F150
Oct 13, 2012 12:02 AM
gofish
Jan 25, 2010 07:13 PM
HwyF150
Aug 7, 2009 07:32 AM
97ExpGuy
Modular V8 (4.6L, 5.4L)
May 18, 2009 07:38 PM
FastDEW
Modular V10 (6.8l)
30
Feb 16, 2007 08:48 PM
