Brakes on 4x2: replace hub when replace front rotor?
Old Sep 17, 2007 | 10:10 AM
H1449-6's Avatar
H1449-6
I've had vibration on braking. Service guy says the rotors are near the end of the useful life. He says that to replace the fronts I will need to replace the hubs too because they are all one unit. Truck is an 00 Limited 4x2 with the V10.
Is this true?
BTW: he's quoting me $160 to turn all four rotors and $980 or so to replace all four. Pads are at 75-85% and will be reused.
Seems a little high for the turn but VERY high for the rotors.
Old Sep 17, 2007 | 12:26 PM
Monsta's Avatar
Monsta
Sit. Stay.
That doesn't sound right at all.
Get your rotors resurfaced somewhere else. Reburnish your stock pads or replace with Hawks. Stock pads are usually the problem with a lot of the "warped" brake problems folks experience with these trucks.
Make sure it is the brakes creating the vibration. Do you feel the pulse creeping up to a stop with your foot on the brake? Do you only get from a high speed slow down? If so, that points (usually) to the steering components worn or in my case, the need for a stabilizer up front due to road irregularities.
Old Sep 17, 2007 | 05:25 PM
igotoneforya's Avatar
igotoneforya
If you can, pull them off and let a parts store turn them. Most turn rotors for free like auto zone and advance auto. I did that with a bronco and was happy with result. A free check to see what is wrong.
Good luck
Old Sep 17, 2007 | 06:56 PM
npccpartsman's Avatar
npccpartsman
It is high for rotors. You can get some extremely high end/high performance rotors and pads for less than that. Applied rotor technologies sells cryo rotors and pads for all four wheels for 772 plus shipping. I've never seen a rotor turned free, but usually about $10 is normal--sometimes $15. I would NOT reuse pads on new rotors. You're asking for trouble and very shortened rotor life. The front hub/rotor is all one piece on the 2wd units, BTW. Most come with the bearing races already in them, but you'll need new bearings. You should have the rotor thickness checked before they are turned. Minimum should be around 1.417"--at least that's for the 03/04's usually the same.
Old Sep 18, 2007 | 08:53 AM
vettdvr's Avatar
vettdvr
I paid $10 to have my rotors turned then used Wagner Prem. Ceramic pads and have had no issues.
Old Sep 18, 2007 | 09:00 AM
igotoneforya
Dang, times changed on me. I did mine at advance auto and I just called them and the franchise gave that up almost 2 years ago they said. Oreilly Auto still does it but now charge 13 for Super Duty, less for pass cars.
Still cheaper than other route, and I agree on never reusing pads.
Old Sep 21, 2007 | 02:57 PM
BAJI26's Avatar
BAJI26
How tight should be the nut that holds the rotor on? I hand tightened it snugg enough that the rotor spins freely and that the cotter pin can go on, the rotor doesn't shake back and forth.
I just wanna know that I tightened it correctly. Thanks!
Old Sep 22, 2007 | 07:44 AM
npccpartsman
I'm sure that everyone has their own way, but when I repack I usually tighten the nut tight tight to seat the bearings and back off just a little so it spins freely. Some even have a torque spec, but I don't think the Fords do.
Old Sep 22, 2007 | 08:19 AM
vettdvr's Avatar
vettdvr
This is a good technique but be rotating the bearings when you tighten the nut. Then stop rotating and back off the nut, this will keep the bearings seated. Then I finger tighten the nut.
Old Nov 27, 2007 | 09:00 PM
Monsta's Avatar
Monsta
Sit. Stay.
Old thread resurrected.
I'm doing my brakes today. Rotor and bearing are NOT one assembly. Rotors are repackable...like all should be.
I'm still searching for the torque specs and procedures. I KNOW they're here somewhere...
Bushwhacker1
2009 - 2014 F150
34
Jan 21, 2017 08:54 AM
DAPtomey
Nov 28, 2016 01:16 PM
blueoval65
Aug 11, 2016 02:46 PM
BolognaBlake
Jun 18, 2016 06:51 AM
JoeI57
1997 - 2003 F150
Aug 28, 2004 06:36 PM
